Canon PowerShot A3400 IS Flash Assembly Replacement
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Battery: step 1, image 1 of 1
      • Place thumb on area right next to where it says open and slide to the right to open.
      Ask FixBot
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: step 2, image 1 of 1
      • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
      Ask FixBot
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: step 3, image 1 of 2 Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: step 3, image 2 of 2
      • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
      Ask FixBot
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: step 4, image 1 of 2 Canon PowerShot A3400 IS Flash Assembly Replacement: step 4, image 2 of 2
      • Place the camera on to the side that has the image stabilizer label.
      • Remove the 5.00 mm screws that are on this side using the screwdriver.
      Ask FixBot
    3. Canon PowerShot A3400 IS Flash Assembly Replacement: step 5, image 1 of 1
      • Place camera on to the side with the A/V Out Digital Cover facing up.
      • Remove this visible 5.00 mm screw.
      • Pull the A/V Out Digital cover back to uncover the next step.
      Ask FixBot
    4. Canon PowerShot A3400 IS Flash Assembly Replacement: step 6, image 1 of 1
      • Remove the 5.00 mm screw from behind the cover.
      Ask FixBot
    5. Canon PowerShot A3400 IS Flash Assembly Replacement: step 7, image 1 of 1
      • Make sure the battery cover is open.
      Ask FixBot
    6. Canon PowerShot A3400 IS Flash Assembly Replacement: step 8, image 1 of 2 Canon PowerShot A3400 IS Flash Assembly Replacement: step 8, image 2 of 2
      • Turn the camera onto the side with the A/V out Digital cover.
      • Use your finger to pull this tab to the right.
      Ask FixBot
    7. Canon PowerShot A3400 IS Flash Assembly Replacement: step 9, image 1 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement: step 9, image 2 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement: step 9, image 3 of 3
      • Remove the lens side by using your fingers or a spudger to pry it gently open.
      • Try to pry it loose all around that side so that it is easier to pull off.
      Ask FixBot
    8. Canon PowerShot A3400 IS Flash Assembly Replacement: step 10, image 1 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement: step 10, image 2 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement: step 10, image 3 of 3
      • Using your fingers, pull the screen side gently off.
      • Try to loosen it all around that side so that it is easier to try and pull it off.
      Ask FixBot
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: step 11, image 1 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: step 11, image 2 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: step 11, image 3 of 3
      • Remove the three 5 mm screws
      Ask FixBot
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: step 12, image 1 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement: step 12, image 2 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement: step 12, image 3 of 3
      • Remove the screen by pulling at the two points as shown.
      Ask FixBot
    3. Canon PowerShot A3400 IS Flash Assembly Replacement: step 13, image 1 of 2 Canon PowerShot A3400 IS Flash Assembly Replacement: step 13, image 2 of 2
      • Remove the metal plate with the plastic opening tool.
      Ask FixBot
    4. Canon PowerShot A3400 IS Flash Assembly Replacement: step 14, image 1 of 2 Canon PowerShot A3400 IS Flash Assembly Replacement: step 14, image 2 of 2
      • Remove the 5 mm screw
      Ask FixBot
    5. Canon PowerShot A3400 IS Flash Assembly Replacement: step 15, image 1 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement: step 15, image 2 of 3 Canon PowerShot A3400 IS Flash Assembly Replacement: step 15, image 3 of 3
      • Gently pull the flash assembly away.
      Ask FixBot
2 other people completed this guide.
Emily Pretorius
349 Reputation
3 Guides authored
1 Guide Comment
easy to take off but waste of putting it back together..
The Heat - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,005
