Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not turn on
Despite your best efforts, your camera will not turn on.
Camera's Power Button
When you turn on your camera, check that the red light next to the power button illuminates. The rid light should be lit when the camera is on. If the red light is not illuminated, a faulty battery may be the cause of the problem.
Faulty Battery
If you camera will not turn on, check that the battery is charged. Try replacing the batteries. If the battery is unable to charge, order a replacement battery.
Faulty Screen
Your camera may actually be on, but the screen may be not displaying correctly. If the batteries are not the problem, your screen might be at fault. Try replacing the screen: Canon PowerShot A2200 LCD Screen Replacement
Zoom lens will not extend/retract
Camera has power but the zoom lens will not extend out of the body.
Camera was interrupted while zoom lens was extending
If your zoom lens was interrupted while extending, possibly by a finger or a camera case, power off your camera and power it on again.
Lens is jammed due to sand or dirt
The camera lens may not extend/retract due to dirt. Use compressed air to blow away any sand or dirt around the outside of the lens. To access the inside of the camera lens for cleaning, consult this guide: Canon PowerShot A2200 Lens Assembly Replacement
Lens is faulty
Due to impact or mechanical issues, the lens may be broken. Try replacing the lens. Canon PowerShot A2200 Lens Assembly Replacement
Camera does not take pictures
The camera is on, but it will not take pictures and store them to the memory card.
Locked Memory Card
Memory cards have a physical lock switch. Remove the memory card and double check that the switch is in the unlocked position.
Full Memory Card
Your memory card may be full and has no more room to store pictures. Make sure that your memory card has memory left over for new pictures.
Video Mode
Your camera may be on video mode and therefore unable to take pictures. Change your shooting setting to a picture mode and see if the camera will take pictures.
Malfunctioning Trigger Button
If it is obvious that the camera is not taking pictures because of one of the previous issues, your trigger button may be damaged. Follow this guide to check for dust or dirt under the trigger button, or to replace it: Canon PowerShot A2200 Button Assembly Replacement
Flash does not work
When you take a picture the flash will not discharge
Flash isn't turned on
The most common reason for the flash not discharging is that the flash is not turned on. The flash settings are located in the menu. For more detailed instructions for turning on the flash, consult the instruction manual.
LCD screen is not working
The camera has power but the LCD screen is black or improperly displaying images.
Broken Screen
Your screen may be damaged due to impact or mechanical issues. Follow this guide to replace the LCD screen: Canon PowerShot A2200 Lens Assembly Replacement
Author
with
Benjamin Gee
983 Reputation
5 Guides authored
Baylor, Team 4-5, Williams Spring 2015 Member of Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Members
72 Guides authored
7 Comments
Dear Sir My Camera New Battery Volts All so Measured 3.7 V Is Sowing.But Camera Not Getting On. LED All So Not ON Please Help Me What is the problem.
Radhakrishnan - Reply Share
When someone says “the flash is not working,” they usually mean “it doesn’t work”! If they didn’t know how to turn it on, they would say so. So it is not helpful to suggest turning on the flash in response to that problem; in fact, it is worse than not helpful, it is downright stupid.
slkramer - Reply Share
My camera turns on, I can see the pictures I’ve taken, and when in auto (or any other mode) all I see is the cameras icons, no video or image. Any Ideas?
Brian B - Reply Share
Also, there is backlight, but still no image.
I move camera button in the right direction but the battery didn't pop out
Carolyn King - Reply Share
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 80
All Time: 6,155
