Up to 20% off select tools
Canon PowerShot A2200 Button Assembly Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
93
All Time:
1,418
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide requires that you use a Phillips head screwdriver to remove the screws holding the buttons in place.
    1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: step 1, image 1 of 1
      • First, remove the batteries and memory card.
      • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
      • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
      Ask FixBot
    2. Canon PowerShot A2200 Button Assembly Replacement: step 2, image 1 of 1
      • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
      Ask FixBot
    3. Canon PowerShot A2200 Button Assembly Replacement: step 3, image 1 of 1
      • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot A2200 Button Assembly Replacement: step 4, image 1 of 3 Canon PowerShot A2200 Button Assembly Replacement: step 4, image 2 of 3 Canon PowerShot A2200 Button Assembly Replacement: step 4, image 3 of 3
      • Begin taking off the back cover with a plastic opening tool.
      • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
      • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
      • Continue taking off the back cover along the left side of the camera as seen in the third picture.
      Ask FixBot
    5. Canon PowerShot A2200 Button Assembly Replacement: step 5, image 1 of 3 Canon PowerShot A2200 Button Assembly Replacement: step 5, image 2 of 3 Canon PowerShot A2200 Button Assembly Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to separate the top section of the back cover from the frame.
      • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
      Ask FixBot
    1. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: step 6, image 1 of 2 Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: step 6, image 2 of 2
      • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
      • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
      Ask FixBot
    2. Canon PowerShot A2200 Button Assembly Replacement: step 7, image 1 of 1
      • Gently lift of the buttons for replacement. They should come off without excessive force.
      • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
      Ask FixBot
Author
with
Benjamin Gee
983 Reputation
5 Guides authored
Baylor, Team 4-5, Williams Spring 2015 Member of Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 93
All Time: 1,418
