Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Projector Does Not Turn On
The projector will not respond or show any sign of powering up.
Faulty Power Cable
Check to see if the power cord is plugged into the power outlet and the correct port on the projector. Also check power cord’s overall condition. If it is worn, replacing it could solve the issue. Additionally, check to make sure all other wires are connected to the correct ports.
Dust Accumulation
The projector could have accumulated dust over time. If so, try to get as much dust out as possible. Clean the vents and filters of the projector, also check the lamp for any dust build up. Clean the lamp surrounding area if necessary.
Faulty Fan
The projector overheating can cause power loss. Make sure the projector is in a well ventilated room and not placed directly in sunlight. Make sure the vents are not blocked and that the fan is free from any jams. If these steps do not solve the issue, it is likely that the fan is broken. The fan would then need to be replaced to ensure the projector cools properly to remain at the proper operating temperature.
Fan Replacement Guide
Faulty Main Board
If none of these steps work, you may need to replace your main board.
Distorted Image
Image does not display as desired when projected onto the screen.
Unfocused Image
The image could be out of focus because the lens is scratched or damaged. Check to make sure the focus settings on the projector and computer are correct.
Dirty Lens
Disconnect the AC power cord, and wipe the lens with a cleaning cloth with a little bit of lens cleaner. Be careful about the cleaner you use, harsh chemicals will damage the lens. You can also replace the lens cover if the lens cannot be cleaned by hand.
Unsecured or Faulty Wire
Check if all the wires are properly connected and secure. Securing a wire means that the wire is locked in place allowing the minimum amount of movement. Make sure it is completely connected to the projector. Check to see if the video wire is the issue by using a different one.
No Sound
You have trouble hearing sounds from the projector, or no sound is emitted at all.
Cable Connection
Make sure that the audio cable is connected.
Faulty Internal Speaker
Make sure the volume on the projector is on. Make sure the settings on your computer are set to output the sound though the projector speakers and not through the computer. If these steps don’t solve the problem, the speaker on the projector might be faulty which means it will need to be replaced.
Faulty External Speaker
Make sure the volume is at the appropriate level and not muted on the projector, your computer, or the external speaker. Make sure the speaker setting on your computer is set to output sound to the external speakers. Check to make sure to the audio cables are plugged into the appropriate input and output ports. If the problem persists, you should try another external speaker.
No Image is Displaying
Cable Connection
Check to see that the projector is plugged in and the power outlet functions correctly. Also make sure all the power cables and visual cables don't have any bent pins.
Fading Projected Image
The bulb is probably fading. Bulb replacement is likely necessary. A common mistake is replacing the bulb with a bulb of the wrong wattage which could damage your projector. Ensure the wattage type is correct before installation.
Bulb Replacement Guide
Dying Lamp
If the lamp is dying, the brightness of the projected image will be affected. The lamp could have worn out over time, and will need to be replaced. The lamp is not to be mistaken as the bulb, as this is a common mistake when troubleshooting image issues.
shane
127 Reputation
0 Guides authored
USF Tampa, Team 9-3, Lacy Fall 2016 Member of USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
4 Members
36 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 45
All Time: 1,017
