Up to 20% off select tools
Canon 7210 Bulb Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
96
All Time:
833
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the bulb. This part will commonly burn out and need to be replaced, so knowing the steps to this simple repair will be very useful for a consumer.
    1. Canon 7210 Bulb Replacement, Bulb: step 1, image 1 of 1
      • Unscrew the 9mm Phillips #0 screw and remove the panel.
      Ask FixBot
    2. Canon 7210 Bulb Replacement: step 2, image 1 of 1
      • Unscrew the two 7mm Phillips #0 screws that attach the bulb to the mainframe of the projector.
      Ask FixBot
    3. Canon 7210 Bulb Replacement: step 3, image 1 of 1
      • Remove the bulb housing by gently pulling on the small silver handle located on top of the bulb housing.
      Ask FixBot
    4. Canon 7210 Bulb Replacement: step 4, image 1 of 1
      • You may replace the entire housing unit or replace the bulb itself once you remove it from the housing unit.
      Ask FixBot
    5. Canon 7210 Bulb Replacement: step 5, image 1 of 1
      • Unscrew the 9mm Phillips #0 screw.
      Ask FixBot
    6. Canon 7210 Bulb Replacement: step 6, image 1 of 1
      • Pull the wire tubing out of the plastic holder.
      Ask FixBot
    7. Canon 7210 Bulb Replacement: step 7, image 1 of 1
      • Pull the bulb out of the casing.
      Ask FixBot
Author
with
William Christian
331 Reputation
3 Guides authored
USF Tampa, Team 9-3, Lacy Fall 2016 Member of USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 96
All Time: 833
