Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Power Cuts off
The curler randomly turns off or stops spinning, no sign of power.
Not plugged in
Make sure the power chord is properly plugged into the outlet. Check for any signs of loose power chord to the curler.
Hair gets stuck in the barrel
Curler may shut off if there is hair stuck in the barrel. Make sure the barrel is clean and free of any excess hair or buildup.
Tripped circuit
Check to make sure the outlet the curler is plugged into is working, try another outlet.
Faulty power cord
If the is no sign of power to the curler, the chord may be faulty. Replace the power chord using this guide.
Faulty Motherboard
If the curler is not turning on, but the power cord is still intact, the motherboard may need to be replaced by following this guide.
Barrel Constantly Spins
Even after curling the strand of hair is done, the curler keeps spinning.
Button is Stuck
Make sure the button is popping back out fully when done curling. Make sure there is nothing pushing the button down or making it stick. Clean the space around and under the button.
Faulty spin button
If the button is fully releasing when done curling, the button and electrical component of the spin button may need to be replaced using this guide.
Unable to Clean Easily
You have trouble cleaning the curler.
Buildup of product
If you find there is still buildup of hair products on the curler, wipe down the surfaces and barrel with a little rubbing alcohol on a cotton pad.
Cleaning tool not working properly
If you are using the provided cleaning tool and find it is not working properly or efficiently, make sure that you are inserting the tool properly.
Not cleaning product frequently enough
This curler should be cleaned using the cleaning tool at least once a week depending on how frequently the curler is being used. This will prevent excess build up.
Hair is Easily Tangled
Hair is getting caught in the curler.
Crack in Barrel
Inspect the barrel of the curler, if there are cracks in the ceramic, the barrel may need to be replaced using this guide.
Excess Buildup from Previous Uses
This product may gather buildup of hair product or strands of hair in the barrel, make sure to properly clean this product once a week by using the provided cleaning tool as well as wiping down the surfaces with a cotton pad with a small amount of alcohol, while also removing any hair trapped in the device.
Improper Use of Product
If the hair gets tangled in the product, make sure to turn the curler off, clean out any excess hair, and reset by turning off the device and turning it back on to begin using again.
Temperature Will Not Set
The temperature is not setting, or the wand is not heating up to the correct temperature.
Faulty Temperature Buttons
If the temperature is not being properly set by the buttons, the temperature control switch may need to be replaced and can be done by following this guide.
Faulty Heat Element
If the curler is not heating up to proper temperature, or is heating too high, the heating component will need to be replaced by following this guide.
Flashing Reset
The wand is beeping and flashing reset.
Tangled Hair
If the curler is being used following with a flashing “Reset” and beeping, there may be hair tangled. Turn off the curler, remove tangled hair slowly, and make sure any excess hair is cleaned from the barrel. Turn device back on and begin using again.
Annalise White
530 Reputation
5 Guides authored
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Members
72 Guides authored
6 Comments
Im having a problem where it says reset and beeps but theres no tangled hair. Is there anything i can do to stop this problem?
Gabby Goings - Reply Share
What is the fix for a reset flip button and beeping sound? I’ve tried holding down the power button, but that does not work.
Gina - Reply Share
I am having the same problem
Elizabeth Marini - Reply Share
I dropped mine and inside is loose. Can I twist it back in or do I have to pry everything open? Thanks
kioshi sevilla - Reply Share
Reset lit and beeping, is the Chi Curl n spin broken?
Gina - Reply Share
Past 24 Hours: 2
Past 7 Days: 38
Past 30 Days: 117
All Time: 7,488
