CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement
  1. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Power Cord: step 1, image 1 of 1
    • Use a metal spudger to pry off the silver, shiny trim.
    Ask FixBot
  2. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: step 2, image 1 of 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
    Ask FixBot
  3. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: step 3, image 1 of 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: step 3, image 2 of 2
    • Use a 2 mm flathead to remove the two screws.
    Ask FixBot
  4. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: step 4, image 1 of 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: step 4, image 2 of 2
    • Use a metal spudger to pry open the seams of the device.
    Ask FixBot
  5. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: step 5, image 1 of 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: step 5, image 2 of 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: step 5, image 3 of 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
    Ask FixBot
  6. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Temperature Control Switch: step 6, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the screws on both sides of the temperature control switch.
    • Pop out the control switch.
    Ask FixBot
Annalise White
530 Reputation
5 Guides authored
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 537
