Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Sander Is Not Powering On
Cut/Broken Electrical Cord
The electrical cord may be damaged. Check for cuts or exposed wire.
Broken On/Off Switch
The On/Off switch may be damaged or jammed. This will require you to break down the sander and replace the switch.
Sander Is Operating at Only One Speed or Will Not Change Speeds
Broken Variable Speed Switch
The variable speed switch may be damaged or jammed. You are going to have to take the sander apart to replace the switch.
Sandpaper Is Not Adhering to Sanding Pad
Worn/Damaged Velcro on Sanding Pad
The hook velcro on the sanding pad may be damaged. You are going to want to replace your sanding pad.
Sander Is Not Collecting Dust
Dirty/Clogged Microfilter Dust Canister
Your dust canister may be clogged or full of dust. If your dust canister is clogged you might need to clean or replace it entirely.
Unable to Tighten Socket Head Cap Screw when Replacing Sanding Pad
Stripped Sanding Pad Driver and/or Socket Head Cap Screw
The internal sanding pad driver may be stripped and/or the socket head cap screw. Replace both components.
Sanding Pad Socket Head Cap Screw Will Not Stay Tight During Operation
5 Comments
My sander slows down when I place it on a wood surface
George Wilbur - Reply Share
Sanding pad is rubbing on dust baffle melting both parts
Clayton Leitch - Reply Share
Suggest removing sanding pad and pulling dust baffle off to resolve problem.
My girlfriend refinishes hardwood floors professionally, and this is her preference with this machine. She also runs the sander with a shopvac attached instead of the stock dust canister. Be advised that the dust baffle does act as a mechanical brake to slow or stop the sander's rotation. If removed, the sander might act differently than usual. With dust baffle removed, the sander shouldn't be allowed to spin up to high rates of speed without any load. Spinning too fast will cause the sander pad to gouge the surface on first contact after spinning up while unloaded. It also might damage the bearings over time.
Robert Gerber - Reply Share
When new, the sander comes with a thick grease applied between the dust baffle and the sanding pad. In your case, I imagine this grease has worn away or been saturated with dust. If you want to keep the dust baffle, I suggest finding a very thick grease (preferably nothing that would stain when flung off by the rotation of the sanding pad). Careful grease selection may also be necessary to avoid a type of grease that could damage the rubber of the dust baffle or the sanding pad. Perhaps silicone based grease? As an alternative to grease, you could also try the application of a paste wax product. Johnson and Minwax both make such a wax, for use in woodworking. Suggest cleaning both pad and baffle surfaces to remove old grease and dust prior to applying any paste wax product, as it may not adhere otherwise. Cleaning thoroughly might be less important when adding grease, but is probably wise. Should probably remove sanding pad from sander for this cleaning. Use included wrench slipped under handle assembly.
Both the dust baffle and the sanding pad are available as replaceable parts on ereplacementparts.com and from Bosch directly. I would definitely consider the sanding pad to be a consumable product when under heavy use. Eventually the velcro hooks break off and the thing needs to be replaced. Personally, I'd question how much actual trouble was being caused by this issue and act accordingly. It's my opinion that the dust baffle was poorly designed.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,480
