Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Blu Dash 5.0 Dual SIM Troubleshooting Page
Released September 3, 2013 Model Number D410
Unresponsive touch screen
The touch screen display works but the screen does not respond to touch
Faulty Display
If you can press the power button and turn the display on and off but the screen is still unresponsive, the display may be bad.
Hard Reset
Performing a reset may resolve an issue with an unresponsive screen. This option WILL delete all your data, so make sure the data on your device is backed up.
When the phone is powered off, press and hold the Volume Up and the Volume Down keys at the same time, then press and hold the Power key for 20 seconds until a test screen that shows some available options pops up.
Press the Volume Down key to scroll through the options until it highlights "Factory Reset" then press the Power key to select it.
To see a video of this process, click Here
Faulty Motherboard
If the two solutions above are unsuccessful, then you have a bad mother board. Click Here to see our guide on how to replace the mother board.
Discolored or Grayed-Out Display
The display works, but there are discolored spots that are grayed out
Damaged Display Wire
A display that is grayed out or discolored may be caused by a frayed wire. It may not be necessary to replace this wire, repairing it may solve the issue. Click Here to see how to do this.
Faulty display
If the step above does not work, the display is bad and will need to be replaced.
Slow Performance
The device is very late to respond to touch screen commands and runs slowly in general
Too Many Applications Running
The more apps that are open in the phone, the slower the phone will run. Many phones nowadays employ multitasking, which is a function that allows multiple applications to be open at once. Having too many apps open, however can use up a phones RAM (Random Access Memory). Closing some apps may free up RAM and make the phone run faster.
RAM Limit Reached
Certain applications , like "Clean RAM Memory" and "Battery Doctor Pro", allow you to clean up your RAM in a matter of seconds. These applications can be download from the Goggle Play store.
No Hard Drive Space
The performance of the phone can be affected by the amount of storage that the phone has. Moving applications from the phone storage to the SD card can free up space and make the phone run faster. To do this, follow these steps:
  • Go to your device settings
  • Click on "Application Manager"
  • Select the app you wish to move to the SD Card
  • Under the "Storage" tab, select "Move to SD Card
Reset the Phone
If the phone is still running slowly, performing a reset may resolve the issue. This option WILL delete all your data, so make sure the data on your device is backed up.
To see a video of this process click Here
Phone is not turning on
No matter what you do, you can't get your Blu Dash 5.0 to turn on.
Drained/bad battery
The battery may be completely dead. Insert the charger for at least 15 minutes and see if the phone boots up. If nothing is happening, be sure to verify that the charger is working. Plug the charger into a different phone or use a different charger if you have one available. If these steps don't work, you may have a bad battery. Follow These steps to replace your battery.
Faulty Display
It is possible that it appears nothing is happening because the display is bad and must be replaced.
Faulty Motherboard
If none of the above solutions work, then the problem most likely lies in the motherboard. Follow This guide to determine how to repair the motherboard.
Richard
36,221 Reputation
11 Guides authored
1 Comment
Dual SIM cards not registering in cell?
Buffy Bader - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 23
All Time: 820
