Blu Dash 5.0 Dual SIM Display Cable Replacement
    1. Blu Dash 5.0 Dual SIM Display Cable Replacement, Battery: step 1, image 1 of 1
      • Find the small slot on the bottom left corner of the back panel.
      • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
      • When the back panel is loose enough, use your fingers to remove it completely.
      Ask FixBot
    2. Blu Dash 5.0 Dual SIM Display Cable Replacement: step 2, image 1 of 1
      • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
      Ask FixBot
    1. Blu Dash 5.0 Dual SIM Display Cable Replacement, Display Cable: step 3, image 1 of 1
      • Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
      • The screw holes with the red circle around them hold screws with a 3.5 mm length.
      • The screw holes with the orange circle around them hold screws with a 2.5 mm length.
      Ask FixBot
    2. Blu Dash 5.0 Dual SIM Display Cable Replacement: step 4, image 1 of 2 Blu Dash 5.0 Dual SIM Display Cable Replacement: step 4, image 2 of 2
      • Insert the plastic opening tool into a corner of the plastic panel and gently pry it away from the rest of the phone.
      • Do this for each corner until the panel pops up.
      Ask FixBot
    3. Blu Dash 5.0 Dual SIM Display Cable Replacement: step 5, image 1 of 3 Blu Dash 5.0 Dual SIM Display Cable Replacement: step 5, image 2 of 3 Blu Dash 5.0 Dual SIM Display Cable Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
      • To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
      Ask FixBot
8 other people completed this guide.
Dashaya Toney
876 Reputation
3 Guides authored
UMass Dartmouth, Team 4-7, Miles Fall 2014 Member of UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 100
All Time: 3,543
