Blackberry won't turn on
No matter what you do, you can't get your Blackberry to turn on.
Frozen device
Before taking apart the blackberry, a simple power cycle might be all that is needed to unfreeze the device.
Blackberry Bold 9650 Powercycle
Drained/bad battery
If your Blackberry won't turn on, especially if it hasn't been used in a while, may simply have a drained battery. Connect the device to your computer or AC adapter. Ideally, the Blackberry will recognize it is connected and start to charge. If it will no longer charge then the battery must be replaced.
Blackberry Bold 9650 Battery Replacement
Bad screen
It is possible that it appears nothing is happening because the screen is bad. If it appears the device turns on (lights turn on, you hear noises from the Blackberry, etc) the screen may need to be replaced.
Blackberry Bold 9650 LCD Screen Replacement
Bad Logic Board
If there is no response when attempting to turn on the Blackberry and a power cycle or fresh charge doesn't fix the problem then the logic board may need to be replaced.
Blackberry Bold 9650 Mother Board Replacement
SIM card needs to be replaced
If the Blackberry says the SIM card is missing or can't be read, the SIM card will need to be replaced.
Blackberry Bold 9650 SIM Card Replacement
The keyboard won't work
You can't type anything on your Blackberry.
Frozen device
Bad keyboard
If the device is working properly but the keyboard doesn't work. They keyboard may need to be replaced.
Blackberry Bold 9650 Keypad Replacement
The track pad won't work
The mouse doesn't move around the screen
Frozen device
Bad track pad
If the device is working properly but the track pad doesn't work. They track pad may need to be replaced.
Blackberry Bold 9650 Trackpad Replacement
No sound/poor sound quality
The Blackberry appears to work fine but whenever you try and play sound the audio doesn't work properly.
Frozen device
Bad speaker
If there is an audio problem most likely it is a bad speaker and will need to be replaced.
Blackberry Bold 9650 Buzzer-Loundspeaker Replacement
Ryan
696 Reputation
11 Guides authored
Clemson, Team 2-5, Benson Spring 2012 Member of Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Members
132 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 18,109
