Blackberry Bold 9650 LCD Screen Replacement
  1. Blackberry Bold 9650 LCD Screen Replacement, Battery: step 1, image 1 of 2 Blackberry Bold 9650 LCD Screen Replacement, Battery: step 1, image 2 of 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
    Ask FixBot
  2. Blackberry Bold 9650 LCD Screen Replacement: step 2, image 1 of 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
    Ask FixBot
  3. Blackberry Bold 9650 LCD Screen Replacement, SIM Card: step 3, image 1 of 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
    Ask FixBot
  4. Blackberry Bold 9650 LCD Screen Replacement: step 4, image 1 of 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
    Ask FixBot
  5. Blackberry Bold 9650 LCD Screen Replacement, Back Chassis: step 5, image 1 of 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
    Ask FixBot
  6. Blackberry Bold 9650 LCD Screen Replacement: step 6, image 1 of 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
    Ask FixBot
  7. Blackberry Bold 9650 LCD Screen Replacement: step 7, image 1 of 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
    Ask FixBot
  8. Blackberry Bold 9650 LCD Screen Replacement: step 8, image 1 of 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
    Ask FixBot
  9. Blackberry Bold 9650 LCD Screen Replacement, Mother Board: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
    Ask FixBot
  10. Blackberry Bold 9650 LCD Screen Replacement: step 10, image 1 of 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
    Ask FixBot
  11. Blackberry Bold 9650 LCD Screen Replacement: step 11, image 1 of 1
    • Using a pair of tweezers, remove the three ribbon connectors.
    Ask FixBot
  12. Blackberry Bold 9650 LCD Screen Replacement: step 12, image 1 of 1
    • Remove the mother board by lifting the board upward.
    Ask FixBot
  13. Blackberry Bold 9650 LCD Screen Replacement, Faceplate: step 13, image 1 of 2 Blackberry Bold 9650 LCD Screen Replacement, Faceplate: step 13, image 2 of 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
    Ask FixBot
  14. Blackberry Bold 9650 LCD Screen Replacement, LCD Screen: step 14, image 1 of 1
    • Turn the phone so it is facing up.
    • Use the plastic pry tool to gently pry out the screen.
    • The screen is glued to the phone so it may require some force to remove so use extra caution to prevent the screen from breaking.
    Ask FixBot
  15. Blackberry Bold 9650 LCD Screen Replacement: step 15, image 1 of 1
    • Lift the screen away from the device.
    Ask FixBot
3 other people completed this guide.
Ryan
696 Reputation
11 Guides authored
Clemson, Team 2-5, Benson Spring 2012 Member of Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Members
25 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 37
All Time: 8,965
