Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Vacuum Not Turning On
Vacuum does not turn on when pressing the power button.
Vacuum is Not Plugged in
Plug in the cord to an outlet that works. Try other outlets if necessary and make sure it is plugged in all the way.
Power Button is not Pressed Down
Unplug the vacuum, then plug it back in. Press down on the power button. If it still does not work, try again in a few hours as the machine might have a system in place that turns off the vacuum if it gets too hot.
Loss of Suction in the Vacuum
Vacuum does not pick up dirt and dust as effectively.
Dirt Cup is Full
Open to top of the vacuum to find the dirt collection box. Take out the dirt collection box and empty it. Make sure to remove any obstructions from the red dirt cup.
Filters are Dirty
Check all three filters (2 dirt filters and 1 air filter) and clean or replace as needed. Clean air filter with a damp cloth. Let the filter dry completely. Check replacement guide for instructions to remove the filter(s).
Hose is not Securely Attached
Remove the hose and reattach it to the vacuum making sure the hose clicks into place properly and is not installed at an angle.
Damaged Hose
Thoroughly inspect the hose to check for any cracks or holes that may be affecting the suction power. If needed, replace the damaged hose. Check replacement guide for instructions to replace the hose.
Air Flow Regulator is Set to Open Setting
Change to the closed setting. Air Flow regulator is located at the end of the hose.
Variable Suction Power is Set to Minimum Setting
Set to the maximum setting. This is located between the power button and cord recoil button.
Vacuum Gets Clogged
Vacuum stops picking up dirt.
Obstruction in the Upper Hose
Detach the hose from the vacuum and shake the tube. If this doesn’t work, try pushing a duster, or broomstick completely through the tube. This will push any obstruction out to the end of the hose.
Brush Belt is not Rotating
To access the brush belt, remove the screws at the bottom of the machine and lift the access plate off. Grab the brush and lift at both ends to remove it, then remove hair, debris, etc. If this does not fix the problem, the belt may be broken. Replace the brush belt using this replacement guide.
Dust Escaping from Vacuum
Dust is coming out of the vacuum when powered on.
Dirt Cup is Full
Filter is Installed Incorrectly
Check all 3 filters to make sure they are properly latched on or determine if they need to be cleaned or replaced. Make sure each fitting is completely latched when putting back on.
Damaged Hose
Remove the hose and check for any holes or tears in the tubing. If the hose is damaged, replace the hose. Check replacement guide for instructions to replace the hose.
Vacuum is Overheating
The vacuum overheats when used giving off an unpleasant odor.
Dirt Cup is Full
Filters are Dirty
Obstruction of Airflow
Check the vacuum for obstructions. Examine hose, all three filters (2 dirt filters and 1 air filter), attachments, and brushes for clumped dirt, hair, and debris. Clear any obstructions before putting parts back into place. Check replacement guide for instructions to remove the filter(s).
Power Cord won’t Retract
When you press the rewind cord button, nothing happens.
Knotted Cord
Unplug the power cord from the socket, and straighten out the cord. Make sure the cord is straight with no knots. Press rewind button.
Dirty Rewind Mechanism
Unscrew the top of the vacuum and find the rewinding spool. There are 6 screws, 4 on the bottom and 2 inside under the dirt collection cup. Gently lift up the top of the vacuum. Don’t damage the circuit board by pulling the top completely off! Pull out the cord all the way and clean the spool. Check to see that spool is correctly placed before gently lowering the top back on.
Rewind Mechanism not Engaging
Unscrew the top of the vacuum and find the rewinding spool. There are 6 screws, 4 on the bottom and 2 inside under the dirt collection cup. Gently lift up the top of the vacuum. Don’t damage the circuit board by pulling the top completely off! Make sure the lever on the spool is intact and matches up correctly with the top of the rewind button. Check to see that spool is correctly placed before gently lowering the top back on.
Jorden Carroll
227 Reputation
1 Guide authored
Cal Poly, Team S12-G1, Banghart Winter 2018 Member of Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Members
60 Guides authored
1 Comment
- Your ‘Dust escaping’ and ‘Loss of Suction’ have the same subheading. Additionally, they seem like the same content. Is ‘Dust escaping’ necessary?
Austin Marshall - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 44
All Time: 1,964
