Bissell OptiClean Cyclonic Vacuum Filter Replacements
    1. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: step 1, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: step 1, image 2 of 2
      • Grab hold of both the flex hose handle and the extension wand.
      • Pull straight out to detach the handle from the extension wand.
      Ask FixBot
    2. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 2, image 1 of 1
      • Locate the lock clip on the other end of the flex hose.
      Ask FixBot
    3. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 3, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 3, image 2 of 2
      • Hold down the lock clip to unlock the flex hose from the vacuum.
      • Remove the flex hose from the vacuum.
      Ask FixBot
    1. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: step 4, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: step 4, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: step 4, image 3 of 3
      • After removing hose, place vacuum on back and unclip the top compartment.
      • Open the compartment.
      • Pull the dirt collection box out of the vacuum.
      Ask FixBot
    2. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 5, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 5, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 5, image 3 of 3
      • Place dirt collection box to the side.
      • Locate the Pre-Motor Filter.
      • Pull the filter out by grabbing the pull tab on top.
      Ask FixBot
    3. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 6, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 6, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 6, image 3 of 3
      • Turn vacuum around and locate the filter cover on the bottom.
      • Place fingers in the opening and pull off the filter cover.
      • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
      Ask FixBot
    4. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 7, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 7, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 7, image 3 of 3
      • Take filter out to clean or replace.
      • To clean Dirt Collection Box, unlatch lid and take off.
      Ask FixBot
    5. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 8, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 8, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 8, image 3 of 3
      • Flip Dirt Collection Box over and locate the push tab.
      • Push the Dirt Cup HEPA Media Filter up to take it off.
      • Picture 3 Shows all the filters taken out of the vacuum.
      Ask FixBot
Austin Marshall
130 Reputation
1 Guide authored
Cal Poly, Team S12-G1, Banghart Winter 2018 Member of Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 28
All Time: 1,094
