Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Touch Screen Unresponsive
The touch screen display works, but is unresponsive to user input
Device needs a Soft Reset
If the screen is on and not responding to any input, hold down the power button to turn the display off and on again. If the problem persists move on to the hard reset.
Device needs a Hard Reset
A hard reset will delete all the data off your phone, so make sure to backup any data that you can.
To begin the hard reset, first turn off the phone. Then hold both the power button and up on the volume switch till you see the BLU logo. Once the BLU logo appears, release the power button. Make sure you keep the volume up button depressed until the system menu appears. When the menu appears, use the volume key to select the “wipe data/factory reset” option. Tap the volume up button to confirm. Your phone has now been reset to factory defaults.
Defective Motherboard
If after both the soft and hard reset the touch screen is still unresponsive, your motherboard may be defective. To replace the motherboard, please see our guide here.
Unable to Install Apps
Receiving error messages when trying to install new apps or download any content
Low Internal memory
Delete any media (music, pictures, or videos) or unused applications to free up space from the internal memory.
If you do not want to delete any data, you can insert an external SD card into the phone.
To insert an SD card, remove the back cover from the phone. The SD slot is to the right of SIM card 2, and above the battery. Apps can be saved directly to the SD card by selecting the option from the app store.
If after clearing or adding memory, you still cannot download apps a hard reset may be needed.
Speakers Are Quiet or Distorted
The sound emitted from the speaker is muffled or has a static effect
Device is in Headphone/Silent Mode
Make sure that the volume is turned all the way up.
Then go to the settings and be sure that the “silent” feature and “headphone mode” is turned off. (If a headphone icon on appears on the screen, then this means that headphone mode is activated).
Obstructed Speakers
A clogged speaker grill can degrade audio quality. Ensure that the speaker grill is free of debris.
Defective Speaker
If the sound is programmed to be on, then the motherboard may need to be replaced. Please see our motherboard replacement guide for more help.
Short Battery Life
The battery is depleting rapidly
Charge Cycle needs to be Reset
Fully charged device before allowing the battery to deplete completely before fully charging it again. This will help to maintain the helps if your battery and it's recommended to be performed once a month.
Apps are Continuously Running
Apps can run in the background and deplete your battery. Uninstall or disable apps that are not being used frequently.
Connectivity Services are On
Turning off connectivity services, like WiFi and Bluetooth, will prevent your phone from searching for WiFi networks and/or other devices and increase your battery life.
Faulty Battery
If the issue still persists the battery may be defective. Please refer to thebattery replacement guide for more help with this issue.
Poor Picture quality
Pictures are coming out blurry when taken with the either the front or back camera
Dirty Camera Lens
Ensure that the lens covering the camera is free of fingerprints and dirt. Use a soft, clean rag to clean the lens.
Camera not Displaying an Image
If either camera is not displaying an image, you may have a defective camera module. To replace the front camera, please refer to our guide here. To replace the back camera, please refer to our guide here.
Author
with
Alexander Prasil
555 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Nance Fall 2017 Member of USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Members
72 Guides authored
2 Comments
Device stuck in safe mode usual suggestions for remedy not working
Ronald Cadogan - Reply Share
I somehow locked my blue smartphone Android so now I can't get anything up on my screen like my apps and it goes to a straight line and at the bottom it says emergency so you have to have some kind of code because I don't want to factory reset it I don't want to lose my apps on there what do I do?
Stephanie Kapsouris - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 34
All Time: 1,922
