Sound cuts in and out
There is no sound at all in either side of the headphones.
Damaged external cable
If the external cable is damaged, torn, or severed, you will not be able to hear any sound. You will need to replace or re-solder the external cable.
Damaged thicker red and yellow wire
If the thicker gauge, shielded red and yellow wire is damaged, torn, or severed, you will not be able to hear any sound. You will need to re-solder the thicker red and yellow wire.
No sound in the left ear
There is no sound coming out of the left ear.
Damaged black and blue wire
If the black and blue, unshielded, internal wire is damaged, you will not be able to hear any sound in the left ear. You will need to re-solder the black and blue wire.
Damaged driver
If the driver magnet is damaged, sound quality will either diminish or no sound will be heard on the affected side. Removal and replacement of the headphone driver on the affected side will fix this problem.
No sound in the right ear
There is no sound coming out of the right ear.
Damaged thinner red and yellow wire
If the thinner red and yellow wire is damaged, you will not be able to hear any sound in the right ear. You will need to re-solder the thinner red and yellow wire.
Damaged driver
Headphones fall off head
The headphones are too big for your head and fall off.
Broken 3-D wings
If the 3-D wings are broken, the headphones might fall off your head. You will need to replace the 3-D wings so the headphones will fit properly.
Headphones are uneven on head
The headphones are uneven on your head and not balanced correctly between your ears.
Broken 3-D wings
If the 3-D wings are broken, the headphones might be uneven on your head. You will need to replace the 3-D wings so the headphones will fit properly.
Too much treble
There is too much treble in the music playing through the headphones.
Damaged internal foam
If there is a hole through the internal foam, there will be too much treble in the music. You will need to replace the internal foam.
Not enough bass
There is too little bass in the music playing through the headphones.
If there is a hole through the internal foam, there will not be enough bass in the music. You will need to replace the internal foam.
Nick Levy
183 Reputation
1 Guide authored
Cal Poly, Team 17-19, Forte Winter 2013 Member of Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Members
72 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 25
All Time: 20,247
