Audio Technica ATH-AD500 Driver Replacement
  1. Audio Technica ATH-AD500 Driver Replacement, Speaker Assembly: step 1, image 1 of 1
    • Remove the ear pads by peeling them away from the grill.
    Ask FixBot
  2. Audio Technica ATH-AD500 Driver Replacement: step 2, image 1 of 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
    Ask FixBot
  3. Audio Technica ATH-AD500 Driver Replacement: step 3, image 1 of 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
    Ask FixBot
  4. Audio Technica ATH-AD500 Driver Replacement, Driver: step 4, image 1 of 1
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
    Ask FixBot
  5. Audio Technica ATH-AD500 Driver Replacement: step 5, image 1 of 1
    • Pull the driver out of its bracket.
    Ask FixBot
  6. Audio Technica ATH-AD500 Driver Replacement: step 6, image 1 of 2 Audio Technica ATH-AD500 Driver Replacement: step 6, image 2 of 2
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference How To Solder and Desolder Connections.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
    Ask FixBot
  7. Audio Technica ATH-AD500 Driver Replacement: step 7, image 1 of 2 Audio Technica ATH-AD500 Driver Replacement: step 7, image 2 of 2
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
    Ask FixBot
2 other people completed this guide.
Nick Levy
183 Reputation
1 Guide authored
Cal Poly, Team 17-19, Forte Winter 2013 Member of Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Members
17 Guides authored
2 Guide Comments
where can i buy a replacement driver?
acidxgangster - Reply Share
You can order parts directly from PARTS@ATUS.COM
Nick Levy - Reply Share
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 50
All Time: 11,746
