Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery does not charge
Battery doesn't charge when the power adapter is plugged in.
The cables aren't plugged in correctly
Make sure that your power adapter cables are securely connected to your Chromebook as well as the power outlet.
No power is getting to the Chromebook
Check if the power outlet is working. If it isn't, use another one and try again until you find a working power outlet.
Battery is dead
The battery needs to be replaced. This has to be done by tearing down the Chromebook to get to the battery. The following video will demonstrate how to do this.
Sound not working on device
The device is not giving out sounds that can be heard.
Volume is not set at a high enough level
Go to the bottom right corner of the screen and click on it. Raise the slide bar where the speaker is by dragging it to the right until you start to hear sound.
Faulty audio jack connection
Check if the audio jack is plugged all the way into the Chromebook. If it isn't, push the audio jack into the device until you hear a click.
The second monitor is not working
You have a problem getting an external monitor or TV working with your Chromebook.
Loose connection
Make sure that the HDMI ports on both sides are securely connected to your Chromebook and your monitor or TV.
Power not on for second monitor
Make sure that the monitor or TV is connected to a wall outlet. If it isn't, plug the device in to give it power. Afterwards, turn it on.
Error message appears when loading web pages
Web pages fail when you try to open one.
Not connected to Wi-Fi hotspot
Make sure that you are connected to a Wi-Fi hotspot. This can be checked by clicking on the status area in the bottom right corner of the screen. If you aren't connected to a Wi-Fi hotspot, click on the first option right under your account and select a network to connect to.
Too many tabs are open
Having too many tabs open will effect how the Chromebook performs due to the limited amount of memory they have when compared to standard laptops and desktops. Closing a few tabs might be able to allow web pages to load again.
Restart Chromebook
Too much data in the Chromebook's RAM can cause it to perform slower and cause errors. Restart the device to clear the RAM. This should make the system more responsive.
Error appeared while trying to update Chrome OS
An error occurred while updating Chrome OS.
Lost Internet connection while downloading update
Reconnect your Chromebook to the Internet and update Chrome OS again. This can be done by clicking on the status area in the bottom right corner of the screen. Then, click on Settings. After that, click on About Chrome OS. Then, click on Check for and apply updates.
Update does not start
You should restart your Chromebook and try to update it again. If that doen't work, you will need to reset your device to factory settings. Go to this link and follow the instructions under Reset a personal Chromebook.
Black Screen
Your screen is black but glowing after you turn it on.
Determining the Source of the Problem
First, we need to find out if the problem is only in the display, or if it is something else. To do this follow the steps:
1. Turn the laptop off. Make sure it is all the way off and not just in sleep mode or hibernate mode.
2. Connect an external monitor to the laptop. Then turn on the external monitor.
3. Turn on the laptop. If the external monitor shows a display, then we can conclude that the problem is with the screen on the laptop (possible solutions below). If not, the problem is likely much bigger.
Loose Screen Cable Connector
It is possible that the screen cable connector is loose. To fix this, go to the screen replacement guide and instead of replacing the screen, just reposition the screen connector. Then put the screen back together and see if the problem is fixed.
Screen Cable Connector is Damaged
If the previous solution does not seem to work, you may need to replace the cable connector.
Connector is Damaged on the Screen
If the above solutions don't solve the problem, you may need to replace the screen.
Laptop Running Slowly
The laptop is not running as fast as it should.
Laptop Working Too Hard
If your laptop is running more slowly that it did in the past, you might have too many processes running at one time. Try finding which unnecessary processes are using a lot of space and stopping or changing them so they don't hog resources.
Needs more RAM
If you need all of the high-demanding processes, you might consider upgrading your RAM. Make sure that your motherboard can support the upgrade though. After you upgrade the RAM, make sure to restart it after a week.
If the motherboard cannot support a RAM upgrade, you might need a more powerful computer. This Chromebook is not suitable for gaming.
Not Connecting to Internet
You are having trouble connecting to the internet.
First, we need to determine if the problem is with the network or with the laptop. To do this try one of the following methods:
- Disconnect from all networks, restart the entire computer, and try reconnecting.
- If you have another internet-capable device, try connecting that to the same network. If it can connect, you know that the problem is with your laptop. If it cannot connect, the problem is likely with the network itself.
- Try connecting the the network using an ethernet cable. If this works, the problem is probably the laptop. If not, the problem is likely the network itself.
The Problem is my Laptop
If you have determined that your laptop is the problem try one of the following:
- Make sure your laptop is fully up-to-date with new updates.
- Run the Google Diagnostics Tool and follow the troubleshooting guide there.
- Uninstall the local network adapter. Reboot the computer. When it starts up again, the computer should automatically install a new driver.
The Problem is the Network
Try resetting the modem.
Laptop Crashing
Your laptop routinely crashes after some time of use.
Virus/Malware Cleanup
You might have some malicious files on your computer. Try running a anti-virus or anti-malware that can cleanup your laptop.
Test RAM/ HDD
It might be the case that your computer is running too slowly to function. Try testing the RAM capabilities to verify.
Factory Reset
Try a complete factory reset, if none of the above suggestions worked.
Not Turning On
Your laptop will not turn on even though it is charged and\or plugged in.
Possible Overload
Try disconnecting all external hardware. Unplug all cables.
Full Reboot
Hold down the Power button for at least 20 seconds to force a full reboot. Then try turning the laptop back on.
Faulty AC Adapter
It could be that your AC Adapter is faulty. Try using a different adapter (with the same voltage) and see if the laptop will turn on.
Reboot RAM
If nothing above is working, try reseating the RAM, then putting it back in place. Then try turning the computer back on.
Display Monitor
It could be that the display is actually the problem. To test this, connect an external monitor and then turn the computer on. If the external monitor shows the computer's display, then the problem is with the screen. You can learn how to replace the screen by following the screen replacement guide. Otherwise, the problem is likely with the motherboard, which you can replace by following the motherboard replacement guide.
Author
with
Christopher Segale
927 Reputation
6 Guides authored
USF Tampa, Team 3-1, Passmore Fall 2016 Member of USF Tampa, Team 3-1, Passmore Fall 2016
USFT-PASSMORE-F16S3G1
4 Members
72 Guides authored
3 Comments
The RETURN Key has stopped working. Cannot delete text. Otherwise keyboard is working OK. Any solutions please?gerrywatcher2@gmail.com
Gerry Landau - Reply Share
I want to fix the corner of my Chromebook screen. When I touch the touchscreen at the corner, it won't work
caitlyn aebersold - Reply Share
Laptop screen black holding power button for 20-40 seconds does nothing?
Tomika Wise - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 15,202
