Asus Chromebook C202SA-YS02 Screen Replacement
    1. Asus Chromebook C202SA-YS02 Screen Replacement, Bezel: step 1, image 1 of 1
      • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
      Ask FixBot
    2. Asus Chromebook C202SA-YS02 Screen Replacement: step 2, image 1 of 1
      • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
      Ask FixBot
    3. Asus Chromebook C202SA-YS02 Screen Replacement: step 3, image 1 of 1
      • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
      Ask FixBot
    1. Asus Chromebook C202SA-YS02 Screen Replacement, Screen: step 4, image 1 of 3 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: step 4, image 2 of 3 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: step 4, image 3 of 3
      • Unscrew and remove the four screws holding the screen in place.
      Ask FixBot
    2. Asus Chromebook C202SA-YS02 Screen Replacement: step 5, image 1 of 1
      • Fold down screen and remove the screen connector band. You may have to use a small flat blade or a spudger, since the latch is very small.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 29
All Time: 3,997
