Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Unresponsive screen
The screen won't respond to touch.
Dirty Screen
If the screen is unresponsive to touch it may be because of streaks of residue or dirt left on the screen from previous use. Wipe down the screen using a microfiber cloth or disinfectant wipe.
Damaged resistive layers
Resistive touchscreens detect touch by detecting the point where the upper and lower layers make contact. When you touch the screen, the upper layer applies pressure on the lower layer to determine the location of the touch. If one of the layers is damaged or broken, it can result in a delayed or unresponsive touch. It is recommended to take your device to your carrier or the nearest phone/tablet repair shop for repair.
Poor battery life
The tablet does not maintain its supposed battery life.
Faulty charger and port
Ensure that the charger is plugged in properly to a stable outlet. Also, check the port to see if there is any dust or debris, and if there is any, use compressed air to remove the built-up debris. If the tablet shows no signs of charge, then consider buying a new charger.
Battery life is low
If the screen is unresponsive to the touch it could be possible that the battery is too low to work. Think about charging the tablet.
Battery
If the charger is plugged in correctly and the tablet only stays on when it is being charged, even if it’s been charged for multiple hours, then it’s a faulty battery. Consider using this battery replacement guide.
Distorted Visual Front Camera
The camera is showing a distorted image or not showing an image.
Dirty Camera
The camera on your tablet is not clean. If there are smudges and marks on the camera it can cause the image to not be clear.
Broken Camera
The camera on your tablet is not working anymore. It can be a faulty front camera causing the image to be distorted or not show. Now you need to replace the front camera so that it can function again. You can do this by following this guide.
Broken display
The glass part of the screen is cracked or chipped.
The screen is chipped/cracked
Accidentally dropping your device may result in chips and cracks on its screen. In such cases, you may need to replace the damaged screen yourself or seek assistance from your nearest mobile carrier. Additionally, it might be worth considering an upgrade for your phone at this point.
Distorted Speaker Audio
The speakers aren’t working properly, sending distorted audio, or dead completely.
Clogged Speaker Ports
Speaker ports can easily get dirty. Start by making sure the volume is all the way up on both the device setting, and any internal software settings as well. If this fails to produce proper sound, you should check to make sure the device is not connected to any external speaker systems such via Bluetooth™ or the audio jack. Be sure to clean out any gunk in our speaker ports with small tweezers or a scraping tool, be sure to be very careful not to damage anything
Internal Driver Failure
All devices use some kind of drives based on their Operating System (OS - the software that the entire device runs on). If the OS is not up to date, then there is a chance that the audio driver is malfunctioning. Let the device fully update and restart to guarantee this isn’t the issue.
Destroyed or Broken Speakers
If both of the above methods fail, there is a component or wiring issue. This can be solved here. This guide will show you how to check the wiring and possibly replace the speakers if they are damaged.
Author
with
Emmanuel Garcia
233 Reputation
0 Guides authored
1 Comment
Touch not work
Mech Arena - Reply Share
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 28
All Time: 837
