Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Alcatel IdealXCITE Will Not Power On
The Alcatel IdealXCITE does not respond to pushing the power button.
The Device is Not Charged
The battery of the Alcatel IdealXCITE may have consumed all its available power and might need charged. Plug the Alcatel IdealXCITE into the provided charging cord or similar aftermarket power cord. According to www.att.com the Alcatel IdealXCITE takes approximately one hour to charge to 50% and 2 hours and 30 mins to charge to 100%.
Charger is Faulty
The charger provided with your Alcatel IdealXCITE may have become damaged and is no longer providing power to your phone. Try visually inspecting the power cord for damage. If you find damage or broken wires the charger may need to be replaced. If the charger does not have any visual signs of damage it may still be the cause of the phone not charging. Try using a different charger to power the device. If this resolves the issue you may have to replace your charger.
Battery is Faulty
Plug your Alcatel IdealXCITE into a working charger. If the phone still does not charge this indicates that there could be a problem with the battery. Failing to charge the phone is a symptom of faulty battery. The battery of the Alcatel IdealXCITE may need to be replaced.
Replace the Battery
Motherboard is Faulty
If the previous attempts to resolve the failure to power on issue have not proven effective, the motherboard may be the cause. The Alcatel IdealXCITE has a motherboard that is easily accessed and easily replaced.
Screen Will Not respond to Touch
The phone screen does not respond or appears to be physically broken.
The Screen is Obstructed
The touch screen of the Alcatel IdealXCITE might be obstructed by previously installed screen protector or case. Try removing the case or screen protector, and gently cleaning the screen with a clean cloth.
The Phone May Have Insufficient Power
Try checking the phone for signs of power by playing the ringtone or checking the power light. If the phone seems to have lower power, try charging the phone. It may take up to 2.5 hours to fully charge the phone.
The Phone May Need a Hard Reset
Occasionally the Alcatel IdealXCITE may become frozen, and a hard restart may resolve the problem. Try removing the battery, waiting 30 seconds and then reinstalling the battery. Once the battery is installed plug it into a charger and attempt to restart the phone normally.
The Screen is Damaged
The touch screen of the Alcatel IdealXCITE may have become damaged through normal use. If the screen is damaged, you may need to replace it.
Phone Will Not Take Photos Using the Rear Facing Camera
The camera is not taking photos or is taking black photos.
The Lens is Obstructed
If you have installed a phone case on your Alcatel IdealXCITE the case may be interfering with the lens. Also, the lens may become dirty during normal use. Try removing the case and attempt to take a photo to see if that resolves the issue. If the lens is dirty, try cleaning the lens with a clean, dry cloth. Attempt to take a photo to see if this has resolved the issue.
The Device Requires a Hard Restart
Occasionally the Alcatel IdealXCITE may fail to properly open the camera application, and a hard restart may resolve the problem. Try removing the battery, waiting 30 seconds and then reinstalling the battery. Once the battery is installed plug it into a charger and attempt to restart the phone normally.
Camera Unit is Bad
Normal use or a hard impact to the phone may have damaged the camera. This may cause the phone to not properly take photos. The camera unit may need replaced.
Audio Is Distorted
You have trouble listing to sounds through the phone.
The Phone Settings are Not Adjusted Properly
During normal use the Alcatel IdealXCITE may have accidentally been switched into mute mode, or the volume setting may have been set too low to hear. Attempt to adjust the volume by pressing the volume control button on the side of the phone, check to make sure the phone is not set into mute or silence mode.
The Phone Case May Be Interfering with Sound Quality
If you have installed a phone case on your Alcatel IdealXCITE the case may be interfering with the speaker. Try removing the case and attempt a phone call to see if that resolves the issue. If the case is interfering with the sound you may need to replace the case.
The Phone is Connected to a Bluetooth Device
During normal use your Alcatel IdealXCITE may have connected to a Bluetooth device. Open the Bluetooth application and check to see if the phone is connected to another device. If it is connected to a Bluetooth device, disconnect the Bluetooth device as it may be transmitting the sound to the other device. Then attempt to make a phone call to check the phone audio.
The Phone Antenna is Damaged and May Need Replaced
If during the use of the phone you experience static or poor audio the cellular antenna may be damaged. Start by checking to see if the poor audio issues are only related to phone calls. Try playing a video or using the phone’s built in alarm. If the phone’s audio works properly and the problem only occurs during calls this may be an indication that the antenna is bad. Attempt replacing the cellular antenna.
Replace the Antenna
The Phone’s Speaker Unit May Be Damaged
Occasional, the Alcatel IdealXCITE’s speaker unit may become damaged. Try playing a video or using the alarm. Also, check the volume and make sure the Bluetooth is not connected to another device. If all other options to correct the poor audio have been unsuccessful the Alcatel IdealXCITE’s speaker unit may be damaged and need to be replaced.
Replace the Speaker
Franklin Froehlich
460 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 462
