Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Darts get stuck in the barrel
When you pull the trigger, you hear the gun fire, but the dart stays put.
Defective dart
First, be sure that it is the blaster that is causing the problem. Some darts can become torn or bent, which can make them lose air or catch on the pin.
Pin is bent
If you hear the gun fire and perhaps see the dart move, but not shoot, the first thing you should check is the pin onto which the dart fits. If it has become bent, it could hold the dart in place, preventing it from firing. If this is the case, try to gently bend it back into place. If this doesn't work, or if the pin snaps, you will have to replace the barrel. For this, you should consult our Air Blasters Tek Six Barrel Replacement guide.
Blaster isn't shooting air
When you pull the trigger, you hear the tension release, but not the sound of air being forced out of the barrel. The dart does not shoot, or travels a much shorter distance than normal.
Plunger has lost its seal
If you hear the blaster fire, but the dart does not move and the pin isn't bent, it's possible that the plunger has lost its seal. This means air is escaping out the side of the plunger, rather than being used to propel the dart. Open up your blaster and check the plunger for leaks. You can attempt to plug small cracks or holes, but it would be easier to just replace it. Check out the Air Blasters Tek Six Plunger Replacement
Trigger feels loose and won't fire
The blaster reloads, but won't fire when you pull the trigger.
Trigger became disconnected
The best-case scenario is that the trigger has simply detached itself from the rest of the internal mechanisms. If you open up your blaster and the orange plastic trigger is not attached at the back of the blaster, simply reconnect it and reassemble your blaster.
Trigger's plastic snapped
However, if the plastic of the trigger itself is broken, you will need to replace it. Check out the Air Blasters Tek Six Trigger Replacement guide.
Blaster won't reload
When you pull the slider back, it doesn't click.
Reload slider became disconnected
If the slider feels loose and doesn't seem to be catching on anything internal, it's possible that it has become disconnected from the rest of the blaster's workings. Open up the blaster and reconnect anything that has come disconnected.
Slider is broken
If the reload slider itself is broken, there is the risk of potentially cutting yourself on a broken piece of plastic. Check out the Air Blasters Tek Six Reload Slider Replacement guide.
Blaster reload slider feels loose
The blaster reloads, but the slider on the top feels loose and does not return to the front upon release.
Reload slider spring is broken/disconnected
If the spring connecting the slider to the front of the blaster is broken or disconnected, the slider will not return to its default position and will feel loose, but the blaster will still reload. Open your blaster and examine this small spring. If it is disconnected, reattach it. If it has snapped, replace it. Check out the Air Blasters Tek Six Reload Slider Spring Replacement guide.
Joshua Taylor
118 Reputation
1 Guide authored
USF Tampa, Team 3-1, Brown Fall 2014 Member of USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Members
60 Guides authored
6 Comments
Hi there. I got a question:
I got a LH hk416 v2, it works absolutely fine shooting without the mag on, but with the mag attached and ammo prime, the blaster only works 100% upside down, but a lot of time when shooting upright (normal position) it just wont shoot (not firing). Can you help?
Gary Royston George - Reply Share
Hey I've got a m4ss and as soon as I connect the battery the gun will continually fire without being turned on or the trigger being pulled do u know Wat the problem would be?
chase.hams - Reply Share
iv got a rx45 desert eagle gell gun it wont fire or load how can i fix this asap
Kiwi Robinson - Reply Share
Blaster won’t open. I have all screws off but I can’t seem to open the blaster.
Jackson Warga - Reply Share
Help required
12-month-old 2021 UMP45 gel blaster with new upgrade battery to 11.1v same issue as I had with the smaller old battery.
Starts fine then slows after 10 to 15 seconds or so, like a dead / dyeing batter but it's not.
What & where to I start to clean & check what's happening / any links for a new be to step by step open & clean / service?
murrayockenfels - Reply Share
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 27
All Time: 8,520
