Air Blasters Tek Six Reload Slider Spring Replacement
    1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: step 1, image 1 of 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: step 1, image 2 of 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: step 1, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the two 11.6 mm screws that hold the grey slider together
      • Remove grey slider from the main body of the blaster.
      Ask FixBot
    2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: step 2, image 1 of 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: step 2, image 2 of 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the six 9 mm screws that secure the main body.
      Ask FixBot
    3. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: step 3, image 1 of 3 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: step 3, image 2 of 3 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: step 3, image 3 of 3
      • Using the plastic opening tools, carefully separate the main case of the blaster to expose the inside.
      Ask FixBot
    4. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: step 4, image 1 of 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: step 4, image 2 of 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: step 4, image 3 of 3
      • Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
      Ask FixBot
    5. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: step 5, image 1 of 2 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: step 5, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the 7.5 mm Phillips #00 screw holding the top spring to the reload slider.
      Ask FixBot
Alfredo Antolinez
347 Reputation
3 Guides authored
USF Tampa, Team 3-1, Brown Fall 2014 Member of USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 35
All Time: 909
