Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet won't turn on
Your tablet won't turn on even if it is fully charged.
Drained Battery
Before opening your device, make sure the battery is fully charged. If it is, read on.
Device won't turn on even when plugged directly into the wall
Try plugging your tablet directly into the wall. If it still will not turn on, it may have a faulty connection within the device. You will have to remove the back cover and check the wiring. If all the wiring is in place, read on.
Battery life is poor
If the device still will not turn on, the battery is probably faulty and the battery will need to be replaced using this guide..
Battery life is very short
Battery life is shorter than what the the manufacturers specify.
Too many running programs
There may be a lot of programs running, causing battery life to be shortened. Try closing the programs that you are not using to see if this increases battery life.
Faulty Battery
The battery may be faulty and will need to be replaced using this guide
No audio or distorted audio through audio jack
Your tablet operates properly and appears to work, but when you plug in headphones or speakers, there is no audio
Faulty headphones or speakers
While this is unlikely, try your tablet with another set of headphones or speakers to eliminate this as the source of the problem right at the beginning.
Faulty audio jack
A bad audio jack is the most likely cause of the problem and will need to be replaced using this guide.
Camera won't turn on
Camera won't turn on when you select the camera app
Operating system error
There may be an operating system error that is causing your camera not to initialize. Try restarting your tablet and reopening the app.
Faulty Camera
More than likely, the camera in the tablet is bad and will need to be replaced using this guide.
No audio/distorted audio from internal speaker
Volume is turned off
Make sure the volume for the speaker is turned up so you can hear it.
Connected to a Bluetooth source
Make sure the device is not connected to a external Bluetooth source.
Faulty internal speaker
If there is still no (or distorted) sound coming from the speaker in your tablet, it is likely the internal speaker is broken and will need to be replaced using this guide.
Touchscreen input not responsive
Your tablet is not recognizing the touch input on the front panel.
Faulty touch screen
It may be possible that the touch screen is bad. If so, the screen will need to be replaced using this guide.
Faulty logic board
If replacing the screen doesn't work, the logic board will need to be replaced using this guide.
Phillip Keavey
319 Reputation
2 Guides authored
1 Comment
Cannot enable wifi
Leon Griffin - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 27
All Time: 2,891
