Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Acer E5-571-54FL Troubleshooting
This page will help you troubleshoot problems with the Acer E5-571-54FL.
Computer Will Not Turn On
The computer does not respond when pressing the power button.
Broken or Defective Power Adapter
If the laptop is plugged into power via the power adapter, check to make sure the charging light on the laptop is on. If it is not, your power adapter is broken or defective. You will need to purchase a replacement adapter.
Broken or Defective Battery
If the laptop is not connected to power via the power adapter and the battery is installed into the laptop, try connecting the power adapter to the computer. If this does not change the computer's behavior, remove the battery. If the computer only turns on when the power adapter is connected or when the battery is not installed, your battery is broken or defective. You will need to purchase a replacement battery. You can use this guide to replace the battery.
Battery Will Not Hold Charge
After charging, the computer does not last as long as it used to when disconnected from power.
Consumed Battery
Batteries have a limited amount of recharge cycles. If, after charging fully, the computer lasts much less time than it has in the past, your battery's charge cycles may be depleted. You will need to purchase a replacement battery. You can use this guide to replace the battery.
If your computer has never lasted long when disconnected from the power adapter, your battery may be faulty. You will need to purchase a replacement battery. You can use this guide to replace the battery.
Computer Turns Off Randomly
During normal operation, the computer shuts down without warning.
Overheating Caused by Dust or Debris in Cooling Fan Shroud Area
If your computer is shutting down randomly and is abnormally hot, your computer may be overheating because there is dust or debris in your computer's fan's shroud. Try spraying compressed air into the computer's air vents to free the dust from the fan.
Overheating Caused by Broken or Defective Cooling Fan or Motor
If your computer is shutting down randomly and is abnormally hot, your computer may be overheating because its cooling fan is not active at all. If this is the case, the fan itself or the fan motor may be broken or defective. You will need to replace the cooling fan. You can use this guide to replace the cooling fan.
Wi-Fi is Slow or Drops Connection Frequently
The computer's wireless internet connection is unstable, disconnects frequently, or will not connect at all.
Incorrect Wi-Fi Drivers
If your computer will not connect to a wireless network or frequently drops connection, you could be using incorrect wireless card drivers. Go to this site and click "Driver". Scroll down to the "Wireless LAN Driver" listing that corresponds to your wireless card's manufacturer and click "Download".
Note: You may have to do this on another computer and transfer the driver to the Acer E5-571-54FL due to the nature of this issue.
Broken or Defective Wireless Card
If your computer does not recognize a wireless card and will not allow you to connect or view networks, your wireless card may be broken or defective. You will need to purchase a replacement wireless card. You can use this guide to replace the wireless card.
Keys are Sticky or Do Not Work When Pressed
Either all or some keys are sticky or, when pressed, do not perform their respective function on the computer.
Debris or Substances Underneath Keys
If a key won't press down fully, there may be debris holding the key up. If a key sticks to the keyboard base after pressing it, a sticky substance or sticky debris may be holding the key down after being pressed. You can use this guide (link to our replacement guide) to remove individual keyboard keys. After removing them, check to make sure there is no debris stuck to the key or beneath where the key is held in place. You may need to wipe off any sticky substances. You can follow the guide to place the back in its original position.
Broken Keys
If there are a few keys that don't perform their respective action when pressed, or feel like you're crushing or cracking something when pressing them, those keys may be broken. You can use this guide to replace the entire keyboard.
Broken or Defective Keyboard
If the computer doesn't respond to any keys, even before it boots up, the entire keyboard may be broken or defective. You can use this guide to replace the entire keyboard.
Liam McIntyre
1 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 40
All Time: 490
