Acer E5-571-54FL Keyboard Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
121
All Time:
2,871
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your keyboard or trackpad no longer respond, this guide will help you access them. Follow each step to minimize damage to your laptop and gain access to the interior.
Tools
    1. Acer E5-571-54FL Keyboard Replacement, Battery: step 1, image 1 of 1
      • Power down the laptop prior to beginning.
      • Turn the laptop over with the battery closest to your body.
      Ask FixBot
    2. Acer E5-571-54FL Keyboard Replacement: step 2, image 1 of 2 Acer E5-571-54FL Keyboard Replacement: step 2, image 2 of 2
      • Insert the pointed end of a spudger into the battery release.
      • Slide the release gently all the way to the left.
      • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
      Ask FixBot
    3. Acer E5-571-54FL Keyboard Replacement: step 3, image 1 of 2 Acer E5-571-54FL Keyboard Replacement: step 3, image 2 of 2
      • Place your hands on each end of the battery.
      • Pull the battery towards your body to remove it.
      Ask FixBot
    1. Acer E5-571-54FL Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
      Ask FixBot
    2. Acer E5-571-54FL Keyboard Replacement: step 5, image 1 of 1
      • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
      Ask FixBot
    3. Acer E5-571-54FL Keyboard Replacement: step 6, image 1 of 1
      • Turn the laptop over so that you can easily open the screen to a vertical position.
      Ask FixBot
    4. Acer E5-571-54FL Keyboard Replacement: step 7, image 1 of 1
      • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
      • Carefully pull up on the center until you hear the tabs disengage from the bottom.
      Ask FixBot
    5. Acer E5-571-54FL Keyboard Replacement: step 8, image 1 of 3 Acer E5-571-54FL Keyboard Replacement: step 8, image 2 of 3 Acer E5-571-54FL Keyboard Replacement: step 8, image 3 of 3
      • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
      • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
      Ask FixBot
    6. Acer E5-571-54FL Keyboard Replacement: step 9, image 1 of 1
      • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
      • You will see three ribbon cables attached to the motherboard.
      Ask FixBot
    7. Acer E5-571-54FL Keyboard Replacement: step 10, image 1 of 3 Acer E5-571-54FL Keyboard Replacement: step 10, image 2 of 3 Acer E5-571-54FL Keyboard Replacement: step 10, image 3 of 3
      • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
      • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
      • Remove the ribbon cable from the connector.
      Ask FixBot
    8. Acer E5-571-54FL Keyboard Replacement: step 11, image 1 of 3 Acer E5-571-54FL Keyboard Replacement: step 11, image 2 of 3 Acer E5-571-54FL Keyboard Replacement: step 11, image 3 of 3
      • Closest to the ribbon cable on the ZIF connector is a black locking tab.
      Ask FixBot
    9. Acer E5-571-54FL Keyboard Replacement: step 12, image 1 of 3 Acer E5-571-54FL Keyboard Replacement: step 12, image 2 of 3 Acer E5-571-54FL Keyboard Replacement: step 12, image 3 of 3
      • On each side of the large connector there are two white tabs.
      • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
      Ask FixBot
    10. Acer E5-571-54FL Keyboard Replacement: step 13, image 1 of 3 Acer E5-571-54FL Keyboard Replacement: step 13, image 2 of 3 Acer E5-571-54FL Keyboard Replacement: step 13, image 3 of 3
      • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
      Ask FixBot
Aaron Weissman
1,043 Reputation
7 Guides authored
3 Guide Comments
hi there , i have a question regarding me having an issue with the keyboard ribbon cable . everytime I reconnect the ribbon cable differents keys stop working or no keys works at all . but if I left the keyboard panel and cable is well extended the whole keys are back working again .
the cable pins are connected correctly I don’t thing the issue is related to the connector end . hope someone can help
adil - Reply Share
Maybe the issue is with the keyboard ribbon cable itself? Or possibly how it is seated in the connector? If it is slightly askew, some of the issues you describe can happen. Try to make sure the cable is seated fully into the connector and as square to the connector as possible. Good luck.
Aaron Weissman - Reply Share
Hi, thanks for the guide, can you please tell me what size the large connector is (step 12)? And can we find the white tab in the market? (broken) Thanks
Mehdi - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 121
All Time: 2,871
