Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Chromebook will not power on
Upon pressing the power button, the system operating light does not illuminate.
Faulty charging port or charger
If your charge indicator light IS NOT illuminated and your device does not power up upon pressing the power button. It is likely a faulty charger port. To determine which is faulty, use a multimeter and test for voltage at the charger plug.
If you have performed the previous test and found there to be no voltage at the plug, replace the charger with a new one from Acer’s website.
Faulty power button
If your charge indicator light IS illuminated but the device will not power on, your power button/switch is likely faulty. On the Acer Chromebook, the power switch is part of the keyboard itself and will require the replacement of your keyboard.
 Flickering or black screen
No pixels are displayed on the screen , however the power light indicates that the computer is running.
Driver issue
If you are experiencing your screen flickering on and off and then suddenly stops and starts going again at random times. Or if you see colors on the display that should not be, then you might have a problem with your driver. Which needs to be updated and can be found on Acer's community website.
Display hardware issue
After verifying that the computer is on and running and not in sleep mode, and the computer display still does not function correctly, your problem is most likely a hardware issue.
Your next step would be to go into developer mode in order to see the problem. If that does not solve the problem still then it would be the display itself being the problem and this guide can be used to replace the screen.
Unresponsive touchpad
No user inputs are detected when interacting with the touchpad.
Software/Chrome operating system issue
To fix an unresponsive touchpad, you should begin by going to settings then going to touchpad and turning off the following features: tap-to-click, touchpad acceleration, and then touchpad speed.
This may get it to work again. Also, often times a simple bug within the Chromebook's OS will prevent the touchpad from working , so a hard reset may help fix this. You can do this by holding the power button and proceeding to press both the power and reset buttons at the same time to reboot and restart your device.
Touchpad residue
Dust can be a big factor in stopping response within a touchpad. A simple way to clean your touchpad is with a soft cloth wipe to remove any unwanted particles such as dust and dirt. After this, proceed to use compressed air to get within the cracks of the touchpad then spray, this should get anything underneath.
Device will not charge
When the charger is plugged in, the battery light does not illuminate.
Faulty battery
If your device only runs while on the charger then dies shortly after removal from the charger, the cause is likely a dead battery. To replace the battery, use this repair guide to remove and replace it.
Faulty charger
If your device was running on battery power previously and now refuses to start when plugged into the charger. The likely cause is a dead charger.
Screen shuts off during use
Chromebook tends to randomly shut off.
Cooling fan connection issue
Before the device shuts off, does it seem hot to the touch while the fan emits no sound? The cooling fan might not be turning on due to a blown motor or a disconnected fan header.
This can cause the device to shut off randomly due to overheating. If it appears that the fan header is connected properly, use this repair manual to remove and replace the cooling fan.
Heatsink residue
Does your fan seem to be running full speed most of the time or make strange noises? The heatsink fan may be clogged with dust, or the blades may be physically obstructed causing drag on the fan.
Clear the dust from the fan with compressed air, and visually inspect for any physical obstruction in the heatsink. If the problem persists, remove the heatsink and reapply the thermal compound by following our repair guide.
Author
with
Fabian Sanchez
247 Reputation
1 Guide authored
Gateway, Team 1-2, Pee Spring 2022 Member of Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Members
48 Guides authored
1 Comment
this is as helpful as a broken arm and almost as much fun
the tawdogg - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 627
