Acer Chromebook C720-2844 Display Screen Replacement
    1. Acer Chromebook C720-2844 Display Screen Replacement, Display Screen: step 1, image 1 of 2 Acer Chromebook C720-2844 Display Screen Replacement, Display Screen: step 1, image 2 of 2
      • Unscrew and remove the 1 cm Phillips #00 screws from motherboard.
      Ask FixBot
    2. Acer Chromebook C720-2844 Display Screen Replacement: step 2, image 1 of 2 Acer Chromebook C720-2844 Display Screen Replacement: step 2, image 2 of 2
      • Unscrew and remove the 1 cm Phillips #00 screw that secures the solid state drive.
      • Lift and pull towards you to remove.
      Ask FixBot
    3. Acer Chromebook C720-2844 Display Screen Replacement: step 3, image 1 of 1
      • Disconnect the 3 cables shown by pulling back evenly from both ends.
      Ask FixBot
    4. Acer Chromebook C720-2844 Display Screen Replacement: step 4, image 1 of 2 Acer Chromebook C720-2844 Display Screen Replacement: step 4, image 2 of 2
      • Unlock the cables shown by lifting the white tab on each.
      • Pull back on the blue tab to remove each cable from the motherboard.
      Ask FixBot
    5. Acer Chromebook C720-2844 Display Screen Replacement: step 5, image 1 of 2 Acer Chromebook C720-2844 Display Screen Replacement: step 5, image 2 of 2
      • Remove the motherboard by shifting to the left and lifting up.
      • Unhook the black and white cables from underneath the motherboard.
      Ask FixBot
    6. Acer Chromebook C720-2844 Display Screen Replacement: step 6, image 1 of 1
      • Unscrew and remove the 1 cm Phillips #00 screws from the display brackets.
      • Lift bracket to detach from the screen.
      Ask FixBot
    7. Acer Chromebook C720-2844 Display Screen Replacement: step 7, image 1 of 1
      • Separate the screen from the shell.
      Ask FixBot
Derek Zevalkink
145 Reputation
1 Guide authored
Gateway, Team 1-2, Pee Spring 2022 Member of Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Members
44 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 398
