Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Short Battery Life
The device will not hold a charge or runs out of battery quickly
Large Load On The Battery
The issue with your battery life being so short may be caused by applications crowding the CPU causing it to drain the battery quickly. Try clearing applications under settings to help improve battery life.
Bad Battery
Another cause might stem from having a bad battery that prevents it from fully charging. You can replace it using the Battery Replacement Guide.
USB Connector Failure
Can not use the USB port to charge the device or transfer data
Debris in The Port
This problem could be caused by something either stuck or broken inside the charging port itself. Try using compressed air to clean out the port.
Bad Cable
Try a different cable. Even if the cable can charge the device, it may not be able to transfer data.
Device Will Not Turn On
The device will not power on
Dead Battery
The battery may not be charging. Try a different charger or replacing the battery. You can replace it using the Battery Replacement Guide.
Device is Damaged
One of the internal components may be damaged. There is no way of pin pointing the problem component. Test it with a charger plugged in. If it powers on then a damaged battery is the likely culprit. You can replace it using the Battery Replacement Guide.
Device Does Not Respond To Touch
Device is not responding to touch or will not show indication of interaction
Heavy Load
Freezing or slow responsive screen touch issues can be cause by applications being frozen causing entire device to not respond. Try restarting your device to clear issue.
Broken Screen
If restarting the device does not solve the issue then may have a broken touch screen.
Dirty Screen
The tablet has a capacitive touchscreen, so if the device's screen is dirty it will have a hard time sensing the users input. Clean the screen and see if the responsiveness improves.
Headphone Jack Will Not Emit Sound
Static or no sound at all emitting through headphone jack
Broken Headphones
The pair of headphones you are using might be broken. Try a different set and confirm that the port is not functioning
Broken Port
The port might be broken. You need to replace the motherboard or the headphone jack. You can replace the motherboard using the motherboard replacement guide
Camera Not Functioning
Camera not responding or just shows a black image
Camera Does Not Respond
The camera software may be unable to communicate with the camera. There can be a software glitch causing this problem. Try restarting the device. Also, try updating the camera app or try a different app that uses the camera to confirm functionality of the camera.
Damaged Camera
The camera in your device might be damaged. If one of the cameras work, but the other does not, it could mean one of the cameras are damaged. The camera will need to be replaced. If both cameras do not work then it is unlikely that both of them were damaged at once unless the device experienced a hard drop or water damage. You can replace the front facing camera using the Front Facing Camera Replacement Guide.
Micro SD Card Storage Issues
Cant read data on the SD card or Device does not show a SD card is inserted
Dust in The Slot
Try taking the SD card out and checking to make sure that the contacts on the card and in the device are clean and unhindered. If it needs to be cleaned, use compressed air.
Incorrect Format Or Corrupted Data
Make sure that your SD card is the correct format for this device. Reformatting the SD card could solve this issue.
Damaged SD Card
You may have a damaged SD card. Try a different one that you know works to see if the device will read it.
Damaged SD Card Slot
You may have a faulty motherboard or SD card slot, if so you will need to replace the motherboard in your device. You can replace the motherboard using the motherboard replacement guide
Samantha Brown
164 Reputation
1 Guide authored
USF Tampa, Team 2-2, Cagle Fall 2016 Member of USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Members
60 Guides authored
3 Comments
My tablet will not come on or the charger icon won't come at all need help
Jennifer Lee - Reply Share
Brand new Asus ZenPad S8 received today. Plugged in as directed and does not charge. The outlet is working and if I press the off/on and hold when I release I get a quick flash of a battery icon with the lightning bolt but no actual charging happening. Has been plugged in for 7 hours and nothing.
jaflady - Reply Share
Brand new Asus ZenPad S8 received today. Plugged in per directions and will not charge. Has been plugged into tested working wall plug for 7 hours and when press power button there is a quick flash of battery icon but no charging happening. What is wrong?
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 10,514
