ASUS ZenPad S 8.0 Motherboard Replacement
    1. ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: step 1, image 1 of 3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: step 1, image 2 of 3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: step 1, image 3 of 3
      • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
      • Use the plastic tool to pry between the silver bezel and the back case
      • Work the tool around the device to free the back case
      Ask FixBot
    2. ASUS ZenPad S 8.0 Motherboard Replacement: step 2, image 1 of 2 ASUS ZenPad S 8.0 Motherboard Replacement: step 2, image 2 of 2
      • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
      • Do not kink the ribbon cables as they can break easily
      Ask FixBot
    3. ASUS ZenPad S 8.0 Motherboard Replacement: step 3, image 1 of 3 ASUS ZenPad S 8.0 Motherboard Replacement: step 3, image 2 of 3 ASUS ZenPad S 8.0 Motherboard Replacement: step 3, image 3 of 3
      • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
      Ask FixBot
    4. ASUS ZenPad S 8.0 Motherboard Replacement: step 4, image 1 of 2 ASUS ZenPad S 8.0 Motherboard Replacement: step 4, image 2 of 2
      • Remove all 9 of the 1.5mm #00 Philips screws
      • Gently lift the battery out of the device
      • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
      Ask FixBot
    1. ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: step 5, image 1 of 3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: step 5, image 2 of 3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: step 5, image 3 of 3
      • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
      Ask FixBot
    2. ASUS ZenPad S 8.0 Motherboard Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a tweezers to lift out the camera
      • If you lifted the latch for the ribbon cable then it should come out with little resistance.
      Ask FixBot
    1. ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: step 7, image 1 of 2 ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
      • The removing of the ribbon cable is done in the same way as the front facing camera.
      Ask FixBot
    2. ASUS ZenPad S 8.0 Motherboard Replacement: step 8, image 1 of 3 ASUS ZenPad S 8.0 Motherboard Replacement: step 8, image 2 of 3 ASUS ZenPad S 8.0 Motherboard Replacement: step 8, image 3 of 3
      Buy
      • Using the tweezers remove the connector gently from the yellow slot
      • Gently peel up the tape until is is completely released from the motherboard
      Ask FixBot
    3. ASUS ZenPad S 8.0 Motherboard Replacement: step 9, image 1 of 2 ASUS ZenPad S 8.0 Motherboard Replacement: step 9, image 2 of 2
      • Cut the warranty tape connecting the motherboard to the metal plate under the battery
      Ask FixBot
    4. ASUS ZenPad S 8.0 Motherboard Replacement: step 10, image 1 of 1
      • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
      Ask FixBot
    5. ASUS ZenPad S 8.0 Motherboard Replacement: step 11, image 1 of 1
      • Gently lift the motherboard from your device
      Ask FixBot
Jessica Voss
319 Reputation
1 Guide authored
USF Tampa, Team 2-2, Cagle Fall 2016 Member of USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Members
60 Guides authored
2 Guide Comments
Where can I buy a spare motherboard for this device.
Partha Tripathy - Reply Share
Where are the motherboard sold and how do I purchase micro USB ports
Xibu Zhang - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 68
All Time: 3,127
