Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device won't turn on
"No matter what you do, the device won't turn on"
Drained Battery
If the device won’t turn on it is possible that the battery is drained. Try plugging the device in for a couple of hours and then try to turn it back on. If this does not solve the problem, then it is possible that the battery will need to be replaced.
If this sounds like something affecting you, Check out the guide for battery replacement below
ASUS MeMo Pad FHD10 Battery Replacement
Damaged Display
If the device has experienced any form of contact with fluids or hard impact, such as water or accidental drops, then it is possible that the screen is damaged. This would result in the device working perfectly fine, but the screen being blank. This would give the appearance of the device not turning on.
Device buttons are not working
"The buttons are stuck or not working, it won't let me perform the function that I want my device to do"
Buttons are dirty
If the buttons are dirty or jammed it is possible that by checking on connections and ensuring that they are not filled with dust or pushed in too far, it will help ensure that your device buttons are working for the entirety of the device’s lifetime.
Buttons are broken
If the buttons are not working, then it is possible that the wired connections for the buttons are not working. Before testing this out, be sure to perform a hard reset on the device by disconnecting and removing the battery from the device and then putting it back in. If this does not resolve the issue then the connections for the buttons may need to be replaced.
Device isn't charging
"When I plug my charger into the device, nothing happens".
Worn cables
It is possible that the cord for the charger is worn out. Check the wires for any signs of wear. This could be anything from unusual kinks in the cable or from frayed and exposed wires. This would all warrant a replacement of the charging cable.
Old/Tired charger
If the Charger has been used for a while, it may simply be time to replace the charging cord. If you can’t afford a new cord, it is possible to charge the tablet from your computer using a USB cord with the proper connections to the Tablet.
Device does not recognize the SD memory
"The device does not respond when I insert a SD memory card"
Micro SD card isn't being Read
If the Micro SD card isn't being read by the device it is possible that the card is being placed into the device incorrectly. If the Micro SD card has to be forced into the device, it is more than likely not in the correct orientation. It is important to ensure that it is in the right orientation to avoid damaging the port for the Micro SD card. This usually can be fixed simply by changing the way that the card is placed into the part. If this does not correct the problem, it is possible that the Micro SD card could be the wrong size, so then a new card of the proper size would fix this problem.
In addition to this, the Micro SD card could be damaged. This could be caused from improper ejection of the card from devices. It could also be a result of malware hidden in files found on the card. This would all result in the card not being read by the device.
Sound is not being made by the device
"The device isn't making any noise while playing music"
Faulty Headphone Jack
If the device is playing music or any other noise and it's not being heard, it is possible that the headphone jack could be misaligned or that it is faulty. This can be fixed by replacing the headphone jack. A replacement guide for the part can be found below
ASUS MeMo Pad FHD10 Headphone Jack Replacement
Alternatively, it is possible that the headphones themselves are faulty, so testing the headphones out on a different device will be helpful in identifying if this is the problem as opposed to the headphone jack.
Distorted Sound from Speakers
If sound is coming from the speakers but it is distorted or barely audible it is possible that you have a problem with the speakers.In this case it would be recommended that the speakers are replaced to correct this problem. A guide to the speaker replacement can be found below
ASUS MeMo Pad FHD10 Speakers Replacement
Camera is not taking pictures
"When I try to take the pictures, the camera will not display what I'm trying to capture"
Damaged Display
If the display is damaged it could be the cause to this problem. By replacing the screen for the device, you should be able to remedy the issue.
Faulty Camera
If the above possibility doesn't pertain to you, then it is possible that the camera within the device itself needs to be replaced. The guide for the camera replacement can be found below.
ASUS MeMo Pad FHD10 Camera Replacement
While working on the replacement, keep in mind that it could also be caused by loosened connections of the camera to the motherboard. In this case, it would still be helpful to follow the repair guide, however a new camera for the device would not be necessary in this instance.
Author
with
Al Muatasim
294 Reputation
2 Guides authored
USF Tampa, Team 9-5, Blackwell Winter 2015 Member of USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Members
60 Guides authored
4 Comments
I am having problems with my ASUS MEMO PAD 10inch Tablet. Launch program, this affecting all other programs.. Can you advise, any: troubleshooting, that I can use?
Theresa Murphy - Reply Share
I have what looks like a memo pad FHD 10 but the model # and other information can't be read due to the size and the irregular surface of the plastic case. It accepts charge but when turned on displays the ASUS in search of Incredidible and remains stuck there. It will shut off but that's it. Can it be booted from the USB or the an SD card?
George Harpur - Reply Share
Found a way to enter the Droid reboot but after factory reset still goes no further. Is there a boot file I can down load?
Display now advising Errors below while in DROIDBOOT mode with droid image and Ready for Download displayed.
unable to open debricking
unable to open pos_enable
FASTBOOT INIT...
FASTBOOT CMD WAITING...
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 6,818
