Car speaker(s) won't play sound
Your speakers are not emitting sound properly, or are not emitting sound at all.
Volume may be low
The volume may be low. Try turning the volume knob or pressing it in to increase the volume.
Fuse may be blown
If a fuse is blown, the speakers will be disabled. Examine the fuses to determine whether they are still intact. 2010-2014 Ford Mustang Fuses Replacement
Speaker may be disconnected
The speaker may be disconnected, check behind the center console to see if wires are all intact. Disassembling 2010-2014 Ford Mustang Center Console
Car won't turn steer properly
Your car is having difficulty turning, or the steering feels unusual.
Tire appears flat or low on air
The tire may be flat or low on air. Check tire's pressure and replace tire if necessary. 2010-2014 Ford Mustang Wheel Replacement
Car appears unaligned
Go to a local shop with your car and have them check if your car is unaligned. Most car shops will perform this check for free.
Poor acceleration
"When you step on the accelerator your car is not going as fast as it used to"
Dirty air filter
The air filter on your car may need to be replaced. See this guide to learn how to inspect and replace the air filter. 2010-2014 Ford Mustang Air Filter Replacement
Front emblem damaged
"The front emblem of your car is damaged and you wish to replace it."
Replacing the front emblem
Replacing the front emblem of the 2011 Ford Mustang is an easy process and will return your car to its former glory. 2010-2014 Ford Mustang New Front Grille Emblem Replacement
Fuse-box replacement
Steering wheel replacement
Removing the center console
Replacing the emblem
Matt Morris
167 Reputation
0 Guides authored
Cal Poly, Team 15-45, Forte Fall 2012 Member of Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
5 Members
72 Guides authored
3 Comments
I have a 2013 Ford Mustang GT and the air bag light turns on when the engine is first started and the blinks once dims abruptly and goes completely out and by the count of 4 going by one-one-thousands the air bag light comes back on steady…and stays in untill the vehicle is turned back off….any suggestions any body….even if there was a away to just turn off the airbag light just so it passes eye sight when I bring it back for emissions testing….
Jeff berthiaume - Reply Share
I have a 2014 mustang v6 I got a code to a speed sensor and I couldn’t find where it gose
Francisco Tanori - Reply Share
My timing chain guide got worn or loose and the timing chain slipped. Whipped around smashed some valves cracked the head and put a hole in a piston. Has this ever happened to anyone else
Hurley - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 36
All Time: 2,707
