Disassembling 2010-2014 Ford Mustang Center Console
  1. Disassembling 2010-2014 Ford Mustang Center Console, Disassembling 2010-2014 Ford Mustang Center Console: step 1, image 1 of 2 Disassembling 2010-2014 Ford Mustang Center Console, Disassembling 2010-2014 Ford Mustang Center Console: step 1, image 2 of 2
    • Open the rear part of the middle console.
    Ask FixBot
  2. Disassembling 2010-2014 Ford Mustang Center Console: step 2, image 1 of 2 Disassembling 2010-2014 Ford Mustang Center Console: step 2, image 2 of 2
    • Grip the right side of the console and pull up towards the passenger seat to remove it.
    Ask FixBot
  3. Disassembling 2010-2014 Ford Mustang Center Console: step 3, image 1 of 2 Disassembling 2010-2014 Ford Mustang Center Console: step 3, image 2 of 2
    • Locate the two bolts under the air conditioning controls at the bottom of the face plate.
    • Loosen these two bolts with a basic socket wrench suited for 7mm bolts.
    Ask FixBot
  4. Disassembling 2010-2014 Ford Mustang Center Console: step 4, image 1 of 2 Disassembling 2010-2014 Ford Mustang Center Console: step 4, image 2 of 2
    • Wedge a spudger or plastic opening tool (in place of the screwdriver shown) under the top of the face plate.
    • Apply pressure until the corners "pop" out of place.
    Ask FixBot
  5. Disassembling 2010-2014 Ford Mustang Center Console: step 5, image 1 of 1
    • Inspect the interior of the center console for damaged wires or other faulty components.
    Ask FixBot
15 other people completed this guide.
Christopher Pell
263 Reputation
5 Guides authored
Cal Poly, Team 15-45, Forte Fall 2012 Member of Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
5 Members
7 Guides authored
4 Guide Comments
Were can I get that faceplate connector and the connectors for the sterio...I have a 2010 v6 mustang
Zack - Reply Share
I found a replacement but need wire configuration for the 4 wires can anyone help ?
beauxvader - Reply Share
Try using the correct tool to remove panels...
hotmail1hotmail - Reply Share
The screwdriver is not required. Nor is any other tool at that point. GENTLY pull from the tabs where you removed the screws.
The faceplate will begin to loosen from the bottom up. After pulling out a few inches, push back inward about a half of an inch. This has the effect of a teeter/totter on the remaining top wedge pins. Now grasp the two knobs on the bottom of the panel (fan and temp) and loosen first the left side and then the right side. No real force required at any time and practically falls out. NO SCARS on the trim.
cheers,
dbw -
davidwest805 - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 155
All Time: 22,592
