« Back to All Stories
iPhone 4 5-Point Pentalobe Screwdriver modification needed
dbuckel -
iPhone 4 Verizon
Story image
iPhone 4 Verizon Rear Panel Replacement
5 minutes
Easy
My Problem
Purchased the screwdriver to repair a broken back cover on an iPhone 4.
My Fix
Fixing the iPhone was very easy and quick. Unfortunately, the screwdriver had to be modified prior to use. The tip of the screwdriver was too long and came to too fine of a point to grip the screw.
My Advice
Very, and I mean VERY, gently grind or file off a small amount of the excess tip. I'd suggest grinding a little and testing the fit and then grinding some more if needed. Be sure to keep the tip square to the grinder.
P2 Pentalobe Screwdriver iPhone Image
$5.99
iPhone 4 (CDMA/Verizon) Blank Rear Glass Panel Image
$9.99
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 205
