iPhone 4 Verizon Rear Panel Replacement
Video Overview
    1. iPhone 4 Verizon Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
      • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
      Ask FixBot
    2. iPhone 4 Verizon Rear Panel Replacement: step 2, image 1 of 2 iPhone 4 Verizon Rear Panel Replacement: step 2, image 2 of 2
      • Push the rear panel toward the top edge of the iPhone.
      • The panel will move about 2 mm.
      Ask FixBot
    3. iPhone 4 Verizon Rear Panel Replacement: step 3, image 1 of 1
      • Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
      • Be careful not to damage the plastic clips attached to the rear panel.
      Ask FixBot
114 other people completed this guide.
4 Guide Comments
Step 1 says the screwdriver should only be used once. Is this correct? Or should it read the screws should only be used once?
Andrew Stevenson - Reply Share
Took less than 10 minutes! Works perfect. Thanks ifixit!
bsterlin - Reply Share
Super simple and easy! done i less than 5 minutes!
Gine - Reply Share
This was a remark made in the products section for the rear glass panel on the Verizon CDMA, "The instructions don't tell you to make sure that you remove the plastic lens from the front facing camera." It is referring to the protective plastic film on the new rear panel that protects the new lens. This should definitely be included in the instructions for replacement of the back panel.
uncletom - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 123
All Time: 48,197
