Up to 20% off select tools
iPhone 16e Screen Replacement
Views: 15K
View statistics:
Past 24 Hours:
43
Past 7 Days:
308
Past 30 Days:
1,268
All Time:
14,789
Comments: 32
32 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 16e Screen
    5
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken, cracked, or non‑responsive screen in your iPhone 16e.
You'll need replacement screen adhesive to complete this repair.
Note: Since you can't disconnect the battery during this repair, be especially careful not to use metal prying tools or touch exposed contacts in your iPhone.
After your repair, calibrate an authentic display using Apple's Repair Assistant.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the procedure.
    1. iPhone 16e Screen Replacement, Before you begin: step 1, image 1 of 2 iPhone 16e Screen Replacement, Before you begin: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power button and either volume button, then slide to power off your phone.
      Ask FixBot
    2. iPhone 16e Screen Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16e Screen Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 16e Screen Replacement, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 16e Screen Replacement, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a pentalobe P2 screwdriver to remove the two 7.8 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 16e Screen Replacement, Mark your opening picks: step 4, image 1 of 3 iPhone 16e Screen Replacement, Mark your opening picks: step 4, image 2 of 3 iPhone 16e Screen Replacement, Mark your opening picks: step 4, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 16e Screen Replacement, Screen information: step 5, image 1 of 2 iPhone 16e Screen Replacement, Screen information: step 5, image 2 of 2
      • For easier screen removal in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive.
      Ask FixBot
    2. iPhone 16e Screen Replacement, Heat the bottom edge: step 6, image 1 of 1
      Tool used on this step:
      iOpener
      $14.95
      Buy
      Ask FixBot
    3. iPhone 16e Screen Replacement, Insert an opening pick: step 7, image 1 of 3 iPhone 16e Screen Replacement, Insert an opening pick: step 7, image 2 of 3 iPhone 16e Screen Replacement, Insert an opening pick: step 7, image 3 of 3
      • The screen consists of a display panel and a bezel. Make sure you insert the pick under the bezel, or you risk separating the two layers and destroying the screen.
      • Apply a suction handle to the bottom edge of the screen.
      • While holding the frame down with one hand, pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    4. iPhone 16e Screen Replacement, Screen information: step 8, image 1 of 2 iPhone 16e Screen Replacement, Screen information: step 8, image 2 of 2
      • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • Two delicate cables connecting the screen to the phone—one next to the Action button and the other about halfway between the volume down button and the bottom of the phone.
      • Multiple spring contacts around the perimeter of the phone.
      Ask FixBot
    5. iPhone 16e Screen Replacement: step 9, image 1 of 3 iPhone 16e Screen Replacement: step 9, image 2 of 3 iPhone 16e Screen Replacement: step 9, image 3 of 3
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the opening pick in the bottom right corner.
      Ask FixBot
    6. iPhone 16e Screen Replacement, Heat the right edge: step 10, image 1 of 2 iPhone 16e Screen Replacement, Heat the right edge: step 10, image 2 of 2
      • Heat the right edge of the screen until it's hot to the touch.
      Ask FixBot
    7. iPhone 16e Screen Replacement: step 11, image 1 of 2 iPhone 16e Screen Replacement: step 11, image 2 of 2
      • Slide your opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive and release the metal clip.
      • You'll hear and feel the metal clip release as you pass it.
      Ask FixBot
    8. iPhone 16e Screen Replacement, Heat the top edge: step 12, image 1 of 1
      • Heat the top edge of the screen until it's hot to the touch.
      Ask FixBot
    9. iPhone 16e Screen Replacement, Separate the top adhesive: step 13, image 1 of 2 iPhone 16e Screen Replacement, Separate the top adhesive: step 13, image 2 of 2
      • Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
      Ask FixBot
    10. iPhone 16e Screen Replacement, Heat the left edge: step 14, image 1 of 2 iPhone 16e Screen Replacement, Heat the left edge: step 14, image 2 of 2
      • Heat the left edge of the screen until it's hot to the touch.
      Ask FixBot
    11. iPhone 16e Screen Replacement, Separate the left adhesive: step 15, image 1 of 2 iPhone 16e Screen Replacement, Separate the left adhesive: step 15, image 2 of 2
      • Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
      Ask FixBot
    12. iPhone 16e Screen Replacement, Prop up the screen: step 16, image 1 of 3 iPhone 16e Screen Replacement, Prop up the screen: step 16, image 2 of 3 iPhone 16e Screen Replacement, Prop up the screen: step 16, image 3 of 3
      • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
      Ask FixBot
    13. iPhone 16e Screen Replacement, Remove the cover screws: step 17, image 1 of 2 iPhone 16e Screen Replacement, Remove the cover screws: step 17, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
      Ask FixBot
    14. iPhone 16e Screen Replacement, Remove the covers: step 18, image 1 of 3 iPhone 16e Screen Replacement, Remove the covers: step 18, image 2 of 3 iPhone 16e Screen Replacement, Remove the covers: step 18, image 3 of 3
      • Use tweezers or your fingers to lift the front sensor cover to a 90-degree angle and unhook it from its slot in the logic board.
      • Lift the cover out of its slot and remove it.
      Ask FixBot
    15. iPhone 16e Screen Replacement: step 19, image 1 of 3 iPhone 16e Screen Replacement: step 19, image 2 of 3 iPhone 16e Screen Replacement: step 19, image 3 of 3
      • Use tweezers or your fingers to lift the screen connector cover at a slight angle to unhook it from its slot in the logic board.
      Ask FixBot
    16. iPhone 16e Screen Replacement, Disconnect the screen: step 20, image 1 of 3 iPhone 16e Screen Replacement, Disconnect the screen: step 20, image 2 of 3 iPhone 16e Screen Replacement, Disconnect the screen: step 20, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the screen press connector.
      • Repeat for the front sensor press connector.
      Ask FixBot
    17. iPhone 16e Screen Replacement, Remove the screen: step 21, image 1 of 1
      • Lift the screen off the frame and remove it.
      Ask FixBot
    1. iPhone 16e Screen Replacement, End of disassembly: step 22, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
      Ask FixBot
    1. iPhone 16e Screen Replacement, Front sensors information: step 23, image 1 of 1
      • The front sensor assembly is located behind the screen, directly beneath the cut‑out for the Face ID sensors.
      • Check if the replacement screen comes with one installed. If it does, skip to this step.
      Ask FixBot
    1. iPhone 16e Screen Replacement, Unfasten the front sensor bracket: step 24, image 1 of 1
      • Use a Y000 screwdriver to remove the two 1.4 mm-long screws securing the sensor assembly bracket.
      Ask FixBot
    2. iPhone 16e Screen Replacement, Remove the front sensor bracket: step 25, image 1 of 2 iPhone 16e Screen Replacement, Remove the front sensor bracket: step 25, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the front sensor assembly bracket.
      Ask FixBot
    3. iPhone 16e Screen Replacement, Heat the front sensor assembly: step 26, image 1 of 2 iPhone 16e Screen Replacement, Heat the front sensor assembly: step 26, image 2 of 2
      • Heat an iOpener and apply it to the top edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
      Ask FixBot
    4. iPhone 16e Screen Replacement, Disconnect the ambient light sensor: step 27, image 1 of 2 iPhone 16e Screen Replacement, Disconnect the ambient light sensor: step 27, image 2 of 2
      • Insert an opening pick between the ambient light sensor and its recess in the screen.
      • Pry up with the pick to separate the ambient light sensor from the screen.
      Ask FixBot
    5. iPhone 16e Screen Replacement, Disconnect the proximity sensor: step 28, image 1 of 2 iPhone 16e Screen Replacement, Disconnect the proximity sensor: step 28, image 2 of 2
      • Insert an opening pick between the proximity sensor and its recess on the screen.
      • Pry up with the pick to separate the proximity sensor from the screen.
      Ask FixBot
    6. iPhone 16e Screen Replacement, Reposition the proximity sensor: step 29, image 1 of 2 iPhone 16e Screen Replacement, Reposition the proximity sensor: step 29, image 2 of 2
      • Use tweezers, or your fingers, to move the proximity sensor cable away from the screen.
      Ask FixBot
    7. iPhone 16e Screen Replacement, Disconnect the microphone: step 30, image 1 of 3 iPhone 16e Screen Replacement, Disconnect the microphone: step 30, image 2 of 3 iPhone 16e Screen Replacement, Disconnect the microphone: step 30, image 3 of 3
      • Insert an opening pick under the microphone cable, close to the microphone (the metal rectangle).
      • Slide the opening pick around the perimeter of the microphone to separate its adhesive.
      Ask FixBot
    8. iPhone 16e Screen Replacement, Remove the front sensor assembly: step 31, image 1 of 3 iPhone 16e Screen Replacement, Remove the front sensor assembly: step 31, image 2 of 3 iPhone 16e Screen Replacement, Remove the front sensor assembly: step 31, image 3 of 3
      • At this point, the adhesive may have cooled down. If so, apply a heated iOpener to the assembly for one minute before continuing.
      • Insert an opening pick under the left side of the front sensor assembly.
      • Slide the pick under the assembly to separate it from the frame.
      Ask FixBot
    9. iPhone 16e Screen Replacement: step 32, image 1 of 2 iPhone 16e Screen Replacement: step 32, image 2 of 2
      • Remove the front sensor assembly.
      Ask FixBot
    1. iPhone 16e Screen Replacement, Install the front sensors: step 33, image 1 of 2 iPhone 16e Screen Replacement, Install the front sensors: step 33, image 2 of 2
      • Align the ambient light sensor with its recess in the back of the screen.
      • Use a spudger or your finger to press the ambient light sensor into its recess.
      Ask FixBot
    2. iPhone 16e Screen Replacement: step 34, image 1 of 3 iPhone 16e Screen Replacement: step 34, image 2 of 3 iPhone 16e Screen Replacement: step 34, image 3 of 3
      • Press the proximity sensor into its recess in the back of the screen.
      • Press the microphone into place next to the proximity sensor.
      Ask FixBot
    3. iPhone 16e Screen Replacement, Press the front sensor cable: step 35, image 1 of 3 iPhone 16e Screen Replacement, Press the front sensor cable: step 35, image 2 of 3 iPhone 16e Screen Replacement, Press the front sensor cable: step 35, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the front sensor assembly cable. It only needs to be warm—not hot.
      • Use your finger to press down the front sensor cable.
      • If the cable isn't sticking, apply a few small pieces of double‑sided tape, like Tesa tape, to the back of it.
      Ask FixBot
    4. iPhone 16e Screen Replacement, Install the front sensor assembly bracket: step 36, image 1 of 2 iPhone 16e Screen Replacement, Install the front sensor assembly bracket: step 36, image 2 of 2
      • Use tweezers or your fingers to install the front sensor assembly bracket.
      Ask FixBot
    5. iPhone 16e Screen Replacement: step 37, image 1 of 1
      • Use a Y000 screwdriver to install the two 1.4 mm-long screws securing the front sensor assembly bracket.
      Ask FixBot
    1. iPhone 16e Screen Replacement, Remove the old adhesive: step 38, image 1 of 2 iPhone 16e Screen Replacement, Remove the old adhesive: step 38, image 2 of 2
      • Use tweezers to remove the adhesive around the perimeter of the frame.
      • You may need to bunch up the adhesive with the point of a spudger before gripping it with tweezers.
      • Use a coffee filter or a lint‑free cloth and high‑concentration isopropyl alcohol (>%90) to clean off any adhesive residue.
      Ask FixBot
    2. iPhone 16e Screen Replacement, Orient the adhesive: step 39, image 1 of 2 iPhone 16e Screen Replacement, Orient the adhesive: step 39, image 2 of 2
      • Lay the adhesive on top of the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
      • Your adhesive may look slightly different.
      Ask FixBot
    3. iPhone 16e Screen Replacement, Apply the adhesive: step 40, image 1 of 3 iPhone 16e Screen Replacement, Apply the adhesive: step 40, image 2 of 3 iPhone 16e Screen Replacement, Apply the adhesive: step 40, image 3 of 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
      • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
      • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
      Ask FixBot
    4. iPhone 16e Screen Replacement: step 41, image 1 of 3 iPhone 16e Screen Replacement: step 41, image 2 of 3 iPhone 16e Screen Replacement: step 41, image 3 of 3
      • Continue peeling the back liner off the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
      Ask FixBot
    5. iPhone 16e Screen Replacement, Press the adhesive into place: step 42, image 1 of 2 iPhone 16e Screen Replacement, Press the adhesive into place: step 42, image 2 of 2
      • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
      Ask FixBot
    6. iPhone 16e Screen Replacement: step 43, image 1 of 3 iPhone 16e Screen Replacement: step 43, image 2 of 3 iPhone 16e Screen Replacement: step 43, image 3 of 3
      • Use the tip of a spudger to lift up the pull tab on the top right corner of the blue adhesive liner until you can grip it with your fingers.
      Ask FixBot
    7. iPhone 16e Screen Replacement: step 44, image 1 of 3 iPhone 16e Screen Replacement: step 44, image 2 of 3 iPhone 16e Screen Replacement: step 44, image 3 of 3
      • Use the pull tab to peel the blue liner off the frame.
      Ask FixBot
    8. iPhone 16e Screen Replacement, Connect the screen: step 45, image 1 of 3 iPhone 16e Screen Replacement, Connect the screen: step 45, image 2 of 3 iPhone 16e Screen Replacement, Connect the screen: step 45, image 3 of 3
      • Prop up the screen along the left edge of the iPhone, using a box or similar sturdy object to support the screen.
      • Use the flat end of a spudger or your finger to connect the screen press connector.
      Ask FixBot
    9. iPhone 16e Screen Replacement: step 46, image 1 of 3 iPhone 16e Screen Replacement: step 46, image 2 of 3 iPhone 16e Screen Replacement: step 46, image 3 of 3
      • Insert the top of the screen connector cover into its slot in the frame and lay it over the press connector.
      Ask FixBot
    10. iPhone 16e Screen Replacement: step 47, image 1 of 3 iPhone 16e Screen Replacement: step 47, image 2 of 3 iPhone 16e Screen Replacement: step 47, image 3 of 3
      • Angle the front sensor connector cover at a 90-degree angle and insert it into its slot in the frame.
      • Lay the cover over the press connector.
      Ask FixBot
    11. iPhone 16e Screen Replacement, Install the cover screws: step 48, image 1 of 2 iPhone 16e Screen Replacement, Install the cover screws: step 48, image 2 of 2
      • Use a tri-point Y000 screwdriver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
      Ask FixBot
    12. iPhone 16e Screen Replacement: step 49, image 1 of 3 iPhone 16e Screen Replacement: step 49, image 2 of 3 iPhone 16e Screen Replacement: step 49, image 3 of 3
      • Use tweezers or your fingers to grip the blue pull tab and remove the liner along the right edge.
      • Without letting the screen touch the adhesive, hold the screen over the phone and remove the other two liners.
      Ask FixBot
    13. iPhone 16e Screen Replacement, Place the screen: step 50, image 1 of 2 iPhone 16e Screen Replacement, Place the screen: step 50, image 2 of 2
      • Hold the screen above the phone and align it with the frame.
      Ask FixBot
    14. iPhone 16e Screen Replacement: step 51, image 1 of 3 iPhone 16e Screen Replacement: step 51, image 2 of 3 iPhone 16e Screen Replacement: step 51, image 3 of 3
      • Lay the screen straight down onto the frame and press until the clips engage.
      • Press around the perimeter of the screen to engage all clips.
      Ask FixBot
    15. iPhone 16e Screen Replacement, Heat the screen: step 52, image 1 of 2 iPhone 16e Screen Replacement, Heat the screen: step 52, image 2 of 2
      • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
      Ask FixBot
    16. iPhone 16e Screen Replacement, Press the screen: step 53, image 1 of 3 iPhone 16e Screen Replacement, Press the screen: step 53, image 2 of 3 iPhone 16e Screen Replacement, Press the screen: step 53, image 3 of 3
      • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
      • If you have the box your iPhone came in, take the lid and place it on a flat surface.
      • If you don't have your original box, skip this step for an alternate method.
      • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
      • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
    17. iPhone 16e Screen Replacement: step 54, image 1 of 3 iPhone 16e Screen Replacement: step 54, image 2 of 3 iPhone 16e Screen Replacement: step 54, image 3 of 3
      • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      Ask FixBot
    18. iPhone 16e Screen Replacement: step 55, image 1 of 3 iPhone 16e Screen Replacement: step 55, image 2 of 3 iPhone 16e Screen Replacement: step 55, image 3 of 3
      • Place one layer of coins or similarly thick objects on the tape along the edges of the back glass.
      • Depending on the thickness of the coins, you might need multiple layers.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      Ask FixBot
    19. iPhone 16e Screen Replacement: step 56, image 1 of 1
      • Stack multiple books or other heavy objects on the iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Ask FixBot
    1. iPhone 16e Screen Replacement, Install the pentalobe screws: step 57, image 1 of 2 iPhone 16e Screen Replacement, Install the pentalobe screws: step 57, image 2 of 2
      • Use a P2 pentalobe screwdriver to install the two 7.8 mm‑long screws on either side of the charging port.
      Ask FixBot
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16e Answers Community for help.
4 other people completed this guide.
Author
with
Alex Diaz-Kokaisl
253,191 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 43
Past 7 Days: 308
Past 30 Days: 1,268
All Time: 14,789
