This teardown is not a repair guide. To repair your iPhone 13 Pro, use our service manual.
    1. iPhone 13 Pro Full Chip ID, iPhone 13 Pro Full Chip ID: step 1, image 1 of 1
      • Logic board, side 1:
      • Apple APL1W07 A15 Bionic SoC layered with what's most likely 6 GB of SK Hynix LPDDR4X SDRAM
      • Apple APL1098 power management IC
      • Apple 338S00762-A1 power management IC
      • STMicroelectronics STB601A05 power management IC
      • Apple 338S00770-B0 power management IC
      • Texas Instruments TPS65657B0 display power management IC
      • NXP Semiconductor CBTL1616A0 display port multiplexer
      Ask FixBot
    2. iPhone 13 Pro Full Chip ID: step 2, image 1 of 1
      • Logic board, side 1 (cont.):
      • Texas Instruments CD3710A1 VCSEL array driver
      • Texas Instruments USB 2.0 dual repeater
      • ON Semiconductor DC-DC converter
      • Possibly a NXP Semiconductor power management IC
      • Possibly a NXP Semiconductor load switch
      Ask FixBot
    3. iPhone 13 Pro Full Chip ID: step 3, image 1 of 1
      • Apple/USI U1 ultra-wideband chip
      • Skyworks SKY58271-19 front-end module
      • Skyworks SKY58276-17 front-end module
      • Likely a Broadcom AFEM-8225 front-end module
      • Likely a Skyworks SKY59723 power amplifier module
      • Likely a Murata 141 RF switch module
      • Likely Broadcom filters
      Ask FixBot
    4. iPhone 13 Pro Full Chip ID: step 4, image 1 of 1
      • Alps HSCDTD00xA electronic compass
      Ask FixBot
    5. iPhone 13 Pro Full Chip ID: step 5, image 1 of 1
      • Logic board, sides 2 and 3:
      • 128 GB of Kioxia NAND flash memory
      • STMicroelectronics ST33Jxxx secure microcontroller w/ eSIM
      • Possibly an Apple/Cirrus Logic 338S00817 audio processor
      • Apple/Cirrus Logic 338S00739 audio codec
      • Apple/Cirrus Logic 338S00537 audio amplifier
      • Broadcom BCM59365 wireless power receiver
      • Likely an Analog Devices haptic driver
      Ask FixBot
    6. iPhone 13 Pro Full Chip ID: step 6, image 1 of 1
      • Logic board, sides 2 and 3 (cont.):
      • Qualcomm PMX60 power management IC
      • Apple 338S00616 power management IC
      • Texas Instruments LM3567A1 LED flash driver
      • Likely a STMicroelectronics DC-DC converter
      • Nexperia 74AVC1T45 3-state voltage level translator/transceiver
      • Nexperia LSF0101 1-bit bidirectional voltage level translator
      Ask FixBot
    7. iPhone 13 Pro Full Chip ID: step 7, image 1 of 1
      • USI 339S00761 WiFi/Bluetooth module
      • Qualcomm SDX60M 5G modem
      • Possibly a Qualcomm SDR868 5G RF transceiver
      • Broadcom AFEM-8215 front-end module
      • Possibly a Skyworks SKY53838-17 front-end module
      • NXP Semiconductor SN210V NFC controller with secure element
      • Likely a Skyworks SKY57217 power amplifier module
      Ask FixBot
    8. iPhone 13 Pro Full Chip ID: step 8, image 1 of 1
      • Qualcomm QET510 envelope tracker
      • Qualcomm QET5100 envelope tracker
      • Likely a Qorvo envelope tracker
      • Likely a Skyworks SKY514xx RF switch module
      • Likely Skyworks RF switch
      • Likely Murata antenna switch module
      • Antenna tuning switch
      Ask FixBot
    9. iPhone 13 Pro Full Chip ID: step 9, image 1 of 1
      • Bosch Sensortec 6-axis accelerometer/gyroscope
      Ask FixBot
Craig Lloyd
43,157 Reputation
82 Guides authored
9 Guide Comments
Which one is the wifi/bt chip?
u2f u2f - Reply Share
Refer to Step 7,
There is no WiFi/BT chip on the main board. Instead, Apple uses USI 339S00761 WiFi/Bluetooth module .
JJ Wu - Reply Share
Is barometer still Bosch’s solution?
JJ Wu - Reply Share
Does anyone know anything more about the USI 339S00761 WiFi/Bluetooth module? Specifically, it would be really interesting to understand if there is Bluetooth LE Audio capabilities hidden there.
Gustaf Rosell - Reply Share
please i need a help my iphone 13 pro i try to restore and gave me error unable to restore idevice (-1)
izeko mobile - Reply Share
Past 24 Hours: 23
Past 7 Days: 136
Past 30 Days: 678
All Time: 68,199
