Battery
6 Answers 0 Score |
Diagnosing microphone problem, where are mics located. |
1 Answer 0 Score |
I need to repair my screen, if I get a non original but compatible? |
1 Answer 0 Score |
True tone works with replacement soft oled screens? |
3 Answers 1 Score |
Replacing an OLED screen with an LCD (To avoid PWM pain issues) |
Documents
Parts
- iPhone 13 Pro Battery
- iPhone 13 Pro Screen
- iPhone 13 Pro/13 Pro Max Rear Camera Lens Covers
- Grip Glass Ultra iPhone 13, 13 Pro, 14, and 16e Screen Protector
- iPhone 13 Pro Display Assembly Adhesive
- iPhone 13 Pro/13 Pro Max Rear Camera Lenses and Bezels
- iPhone 13 Pro Lightning Connector Assembly
- iPhone 13 Pro Aftermarket Blank Rear Glass Panel
Tools
- Clampy - Anti-Clamp
- Spudger
- iOpener
- iFixit Opening Picks (Set of 6)
- Tweezers
- Suction Handle
- Phillips #00 Screwdriver
- Moray Driver Kit
- Plastic Cards
- Heat Gun
- Lint-Free Clean Room Wipes
- iFixit Safety Glasses
- P2 Pentalobe Screwdriver iPhone
- Tri-point Y000 Screwdriver
- Standoff Screwdriver for iPhones
- SIM Card Eject Tool
- iHold EVO
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Models
A2483 US, A2636 CA/MX/JP/SA, A2638 Global, A2639 China, A2640 Russia
Wallpapers
Get your free iPhone 13 Pro and Pro Max teardown wallpapers! Choose from iFixit or Creative Electron (X-ray) versions. Looking for more? Check out our other wallpaper posts!
News
The iFixit team opened up the iPhone 13 and 13 Pro in a livestream teardown extravaganza! Watch that here! Want the full written teardown? Find that here.
Dysfunctional Face ID is plaguing display replacements in early tests—what other part-swapping nightmares does the iPhone 13 hold? Read more at The Parts You Can and Can’t Swap Between iPhone 13 Models.
Background
The iPhone 13 Pro was released on September 24th 2021 alongside the rest of the iPhone 13 lineup. Starting at the same price as last year’s iPhone 12 Pro, Apple’s new flagship maintains the same stainless steel design language and adds a 1 TB storage option, the first for iPhone. Both the iPhone 13 Pro and Pro Max gain a 120 Hz ProMotion display, an entirely upgraded 3-lens camera system, and Apple’s new A15 Bionic.
Featuring five GPU cores over the regular iPhone 13’s four, the iPhone 13 Pro starts at 128 GB and is available in Graphite, Silver, Gold, and Sierra Blue. A larger, 6.7-inch iPhone 13 Pro Max is also available.
The iPhone 13 Pro starts at $999 and can be identified by model numbers A2483, A2636, A2639, A2640, and A2638 depending on region.
Identification
You can identify the iPhone 13 Pro by finding one of the model numbers either on the inner edge of the SIM card tray or within the phone's Settings app:
- A2483
- A2636
- A2638
- A2639
- A2640
You can find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
The iPhone 13 Pro features a 6.1 in (diagonal) flat glass screen, thin black bezels, and a smaller notch at the top of the screen to accommodate a speaker and selfie camera. The back cover is glass and the edge frame is made from flat stainless steel.
Volume controls and the SIM tray can be found on the left edge while the power button is situated on the right. A rectangular camera "bump" containing three cameras in a triagonal layout protrudes slightly from the back case. This model has no home button.
The iPhone 13 Pro can be differentiated from the iPhone 13 Pro Max by the 6.1 in screen (relative to the 6.7 in screen on the Pro Max model).
Specifications
Announce date: September 14th, 2021
Operating System: iOS 15
Display:
- 6.1-inch “Super Retina XDR” OLED
- ProMotion with adaptive refresh rates up to 120 Hz
- Ceramic Shield glass technology
- Multi‑touch
- Haptic Touch
- 2532 × 1170 pixel resolution (460 ppi)
- 2,000,000:1 contrast ratio (typical)
- True Tone
- P3 wide color gamut
- 1000 nits max brightness; 1200 nits max HDR (typical)
- Fingerprint-resistant oleophobic coating
Triple primary camera:
- True Tone flash with Slow Sync
- LiDAR scanner
- Apple ProRAW
- 4K 10-bit HDR video recording with Dolby Vision HDR, up to 60 fps
- 6x optical zoom range
- Wide-angle module
- 12 MP
- ƒ/1.5 aperture
- Sensor-shift optical image stabilization (OIS)
- Autofocus with 100% Focus Pixels
- Seven-element lens
- Ultra Wide module (120° field of view, 2x optical zoom out)
- 12 MP
- ƒ/1.8 aperture
- Six-element lens
- Macro photography
- Telephoto module (3x optical zoom in)
- 12 MP
- ƒ/2.8 aperture
- Six-element lens
TrueDepth selfie camera with Face ID:
- 12 MP
- ƒ/2.2 aperture
- 4K video recording, up to 60 fps
- Retina Flash
Processor: A15 Bionic with 16-core Neural Engine
- 5 nm process
- 6-core CPU
- 5-core GPU
RAM: 6 GB
Storage: 128, 256, 512 GB, or 1 TB
Battery: 3095 mAh, 11.97 Wh
Sensors:
- Face ID
- LiDAR scanner
- Barometer
- Three-axis gyro
- Accelerometer
- Proximity sensor
- Ambient light sensor
Wireless Connectivity:
- 802.11ax Wi‑Fi 6 with 2x2 MIMO
- 5G (sub-6 GHz and mmWave)
- Gigabit LTE with 4x4 MIMO and LAA
- Bluetooth 5.0
- Apple-designed U1 Ultra Wideband chip for spatial awareness
- NFC
Dimensions: 5.78 × 2.82 × 0.30 in (146.7 × 71.5 × 7.65 mm)
Weight: 204 g (7.19 oz)
Water Resistance: IP68
Colors: Graphite, Silver, Gold, and Sierra Blue
