iPhone 12 mini Front-Facing Cameras Replacement
    1. iPhone 12 mini Front-Facing Cameras Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
      Ask FixBot
    1. iPhone 12 mini Front-Facing Cameras Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 12 mini Front-Facing Cameras Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 12 mini Front-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    3. iPhone 12 mini Front-Facing Cameras Replacement: step 5, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement: step 5, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    4. iPhone 12 mini Front-Facing Cameras Replacement: step 6, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement: step 6, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement: step 6, image 3 of 3
      • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
      • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
      • Make sure the opening pick is placed properly between the plastic bezel and the frame to avoid damaging your screen.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    5. iPhone 12 mini Front-Facing Cameras Replacement, Heat the bottom half of the phone: step 7, image 1 of 1
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      • Heating the bottom half of the iPhone helps soften the adhesive securing the display, making it easier to open.
      • Use a hair dryer or a heat gun to heat the bottom half of the iPhone until the screen is slightly too hot to touch.
      • For best practices on using a hair dryer to soften adhesive, check out this guide. For warnings on heat gun use, check out this guide.
      • To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • If you have trouble during the opening procedure, the adhesive most likely cooled down. Apply more heat to further soften the adhesive.
      Ask FixBot
    6. iPhone 12 mini Front-Facing Cameras Replacement, Apply a suction handle: step 8, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Apply a suction handle: step 8, image 2 of 2
      • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      Ask FixBot
    7. iPhone 12 mini Front-Facing Cameras Replacement, Lift the screen slightly: step 9, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Lift the screen slightly: step 9, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Lift the screen slightly: step 9, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the metal frame.
      • A plastic bezel is secured to the underside of the display, and needs to lift up with the display. Inserting a pick between the bezel and the display will damage the panel.
      • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
      • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    8. iPhone 12 mini Front-Facing Cameras Replacement, Separate the bottom edge adhesive: step 10, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Separate the bottom edge adhesive: step 10, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Separate the bottom edge adhesive: step 10, image 3 of 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    9. iPhone 12 mini Front-Facing Cameras Replacement, Heat the right edge: step 11, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Heat the right edge: step 11, image 2 of 2
      • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Ask FixBot
    10. iPhone 12 mini Front-Facing Cameras Replacement, Separate the screen adhesive: step 12, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Separate the screen adhesive: step 12, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Separate the screen adhesive: step 12, image 3 of 3
      • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Ask FixBot
    11. iPhone 12 mini Front-Facing Cameras Replacement, Heat the top half: step 13, image 1 of 1
      • Use a hair dryer to heat the top half of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    12. iPhone 12 mini Front-Facing Cameras Replacement: step 14, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement: step 14, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement: step 14, image 3 of 3
      • The top edge of the display is secured with both glue and clips.
      • Insert your pick underneath the top-right corner of the display panel.
      • Slide the pick around the top right corner. Because of the clips you might encounter some resistance.
      • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
      • Gently pulling the front panel assembly towards the bottom edge of the phone simplifies this step a little.
      • Slide the pick along the top edge and cut any remaining adhesive securing the display.
      Ask FixBot
    13. iPhone 12 mini Front-Facing Cameras Replacement, Heat the left edge: step 15, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Heat the left edge: step 15, image 2 of 2
      • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    14. iPhone 12 mini Front-Facing Cameras Replacement, Separate the left edge adhesive: step 16, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Separate the left edge adhesive: step 16, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Separate the left edge adhesive: step 16, image 3 of 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick down the left edge of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Ask FixBot
    15. iPhone 12 mini Front-Facing Cameras Replacement, Open the iPhone: step 17, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Open the iPhone: step 17, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Open the iPhone: step 17, image 3 of 3
      • Rotate your iPhone so the right edge faces you.
      • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    1. iPhone 12 mini Front-Facing Cameras Replacement, Unscrew the battery and display connector cover: step 18, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Unscrew the battery and display connector cover: step 18, image 2 of 2
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the 1.25 mm-long Y000 screw securing the battery & display connector cover bracket.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    2. iPhone 12 mini Front-Facing Cameras Replacement, Remove the battery and display connector cover: step 19, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Remove the battery and display connector cover: step 19, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the battery & display connector bracket.
      • There are two little hinges on the right edge of the connector bracket. Make sure to align them with their counterparts during reassembly.
      Ask FixBot
    3. iPhone 12 mini Front-Facing Cameras Replacement, Disconnect the battery: step 20, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Disconnect the battery: step 20, image 2 of 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    4. iPhone 12 mini Front-Facing Cameras Replacement, Disconnect the OLED display cable: step 21, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Disconnect the OLED display cable: step 21, image 2 of 2
      • Use a spudger or a clean fingernail to pry the OLED panel cable connector up from its socket on the logic board.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    5. iPhone 12 mini Front-Facing Cameras Replacement, Unscrew the front sensor assembly cover: step 22, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Unscrew the front sensor assembly cover: step 22, image 2 of 2
      • Remove the five 1 mm-long Y000 screws securing the front sensor assembly cover bracket.
      Ask FixBot
    6. iPhone 12 mini Front-Facing Cameras Replacement: step 23, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement: step 23, image 2 of 2
      • Use a pair of tweezers to remove the front sensor assembly bracket.
      Ask FixBot
    7. iPhone 12 mini Front-Facing Cameras Replacement, Disconnect the front sensors: step 24, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Disconnect the front sensors: step 24, image 2 of 2
      • Use a spudger or a clean fingernail to disconnect the front sensor assembly cable connector.
      Ask FixBot
    8. iPhone 12 mini Front-Facing Cameras Replacement, Remove the display assembly: step 25, image 1 of 1
      Ask FixBot
    1. iPhone 12 mini Front-Facing Cameras Replacement, Unscrew the camera module cover: step 26, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Unscrew the camera module cover: step 26, image 2 of 2
      • You can make the front camera assembly removal a bit easier by disconnecting the flex cable of the ultra wide rear facing camera. However it is possible to remove the assembly without doing so but it is more difficult to reinstall the front camera that way. In case you decide not to do so, jump straight to step 23.
      • Remove the two 1.6 mm-long Phillips #000 screws.
      Ask FixBot
    2. iPhone 12 mini Front-Facing Cameras Replacement, Remove the camera module cover: step 27, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Remove the camera module cover: step 27, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the camera module cover bracket.
      • On the right side of the bracket are two little nibs which are tucked into the iPhone frame. Grab the bracket on its left edge and pull it in the direction of the volume buttons in order to remove it safely.
      • During reassembly make sure to align the two metal nibs with their appropriate counterparts in the iPhone frame.
      Ask FixBot
    3. iPhone 12 mini Front-Facing Cameras Replacement, Disconnect the camera flex cables: step 28, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Disconnect the camera flex cables: step 28, image 2 of 2
      • Use a spudger to disconnect the ultra wide angle camera flex cable by prying it straight up from its socket.
      Ask FixBot
    4. iPhone 12 mini Front-Facing Cameras Replacement: step 29, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement: step 29, image 2 of 2
      • Use a spudger to disconnect the dot projector flex cable by prying it straight up from its socket.
      Ask FixBot
    5. iPhone 12 mini Front-Facing Cameras Replacement: step 30, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement: step 30, image 2 of 2
      • Use a spudger to disconnect the selfie camera flex cable by prying it straight up from its socket.
      Ask FixBot
    6. iPhone 12 mini Front-Facing Cameras Replacement: step 31, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement: step 31, image 2 of 2
      • Use a spudger to disconnect the infrared camera flex cable by prying it straight up from its socket.
      Ask FixBot
    7. iPhone 12 mini Front-Facing Cameras Replacement: step 32, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement: step 32, image 2 of 2
      • There's a small nib on the left edge of the camera module which needs to be unhinged before removing the full assembly.
      • Use a spudger to push the front camera assembly a bit to the right until you can see the metal nib on its left edge.
      Ask FixBot
    8. iPhone 12 mini Front-Facing Cameras Replacement, Pry up the front facing camera assembly: step 33, image 1 of 2 iPhone 12 mini Front-Facing Cameras Replacement, Pry up the front facing camera assembly: step 33, image 2 of 2
      • Use a spudger to pry up the front facing camera assembly.
      Ask FixBot
    9. iPhone 12 mini Front-Facing Cameras Replacement, Remove the front facing camera assembly: step 34, image 1 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Remove the front facing camera assembly: step 34, image 2 of 3 iPhone 12 mini Front-Facing Cameras Replacement, Remove the front facing camera assembly: step 34, image 3 of 3
      • Use a pair of tweezers to pull the front facing camera assembly to the left and remove it.
      • The flash flex cable runs underneath the flex cable of the rear facing camera cable. Make sure to layer it underneath the rear camera cable during reassembly.
      Ask FixBot
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 mini Answers community for help.
10 other people completed this guide.
Dominik Schnabelrauch
266,009 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
1 Guide Comment
I bought front camera module online and hoped that will fix the face id issue since the phone had troubles with truedepth camera module and I seen that iOS 18 can recalibrate that but ... it says it's not a genuine part :-D Is there a way to buy somewhere genuine front camera module? What does genuine even mean? Does it need to be from another phone and not a newly manufactured part? Why do they even manufacture them when Face ID will never work with non-genuine parts
Jan Bezdicek - Reply Share
Past 24 Hours: 12
Past 7 Days: 72
Past 30 Days: 316
All Time: 20,535
