iPad Pro 11" 1st Gen Battery Replacement
    1. iPad Pro 11" 1st Gen Battery Replacement, Prepare your iPad for disassembly: step 1, image 1 of 1
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Battery Replacement, Screen removal information: step 2, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Screen removal information: step 2, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Screen removal information: step 2, image 3 of 3
      • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
      • Camera module, ambient light sensors, proximity senor, and front microphone
      • Display cables
      • Screen magnets
      • LCD edges
      Ask FixBot
    2. iPad Pro 11" 1st Gen Battery Replacement, Heat the right edge: step 3, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Battery Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Battery Replacement: step 5, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 5, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 5, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Battery Replacement: step 6, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement: step 6, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    6. iPad Pro 11" 1st Gen Battery Replacement, Insert an opening pick: step 7, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Insert an opening pick: step 7, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Insert an opening pick: step 7, image 3 of 3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
      • Pull up on the suction handle with firm, constant pressure to create a gap large enough to insert an opening pick.
      • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
      • Insert the tip of an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm or you'll damage the LCD.
      Ask FixBot
    7. iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge adhesive: step 8, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge adhesive: step 8, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge adhesive: step 8, image 3 of 3
      • Insert a new opening pick in the gap you just created.
      • Slide the pick along the right edge to separate the adhesive.
      • When sliding near the volume buttons, don't insert the pick more than 2 mm or you'll damage the screen magnets.
      • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    8. iPad Pro 11" 1st Gen Battery Replacement, Heat the top edge: step 9, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Ask FixBot
    9. iPad Pro 11" 1st Gen Battery Replacement, Top edge information: step 10, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Top edge information: step 10, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Top edge information: step 10, image 3 of 3
      • The top edge of the iPad contains the camera module, two ambient light sensors, the proximity sensor, and front microphone. These components are fragile and easily damaged if an opening pick is inserted too far. Only separate the adhesive in the marked locations to avoid damage.
      • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
      • Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
      • Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
      Ask FixBot
    10. iPad Pro 11" 1st Gen Battery Replacement, Separate the top edge adhesive: step 11, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Separate the top edge adhesive: step 11, image 2 of 2
      • Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
      • Don't insert the opening pick more than 5 mm.
      • Leave the pick to the right of the sensor to prevent the adhesive from re-sealing.
      Ask FixBot
    11. iPad Pro 11" 1st Gen Battery Replacement: step 12, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 12, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 12, image 3 of 3
      • Insert a new opening pick to the right of the ambient light sensor.
      • Slide the pick along the middle section of the top, stopping when you reach the left ambient light sensor.
      • Don't insert the pick more than 1 mm or you'll damage the proximity sensor and front microphone.
      • Leave the pick in to prevent the adhesive from re-sealing.
      Ask FixBot
    12. iPad Pro 11" 1st Gen Battery Replacement: step 13, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement: step 13, image 2 of 2
      • Insert a new opening pick to the left of the ambient light sensor.
      • Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
      • Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
      Ask FixBot
    13. iPad Pro 11" 1st Gen Battery Replacement, Heat the bottom edge: step 14, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      Ask FixBot
    14. iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge adhesive: step 15, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge adhesive: step 15, image 2 of 2
      • Insert a new opening pick in the bottom right corner below the existing pick.
      • Don't insert the opening pick more than 2 mm when sliding on the right edge.
      • Slide the pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    15. iPad Pro 11" 1st Gen Battery Replacement: step 16, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement: step 16, image 2 of 2
      • Slide the opening pick along the bottom edge, stopping at the USB-C port.
      • Don't insert the opening pick more than 5 mm when separating the bottom edge adhesive.
      • Leave the pick in to prevent the bottom edge adhesive from re-sealing.
      Ask FixBot
    16. iPad Pro 11" 1st Gen Battery Replacement: step 17, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement: step 17, image 2 of 2
      • Insert a new opening pick to the left of the USB-C port.
      • Separate the remaining bottom edge adhesive.
      • Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
      Ask FixBot
    17. iPad Pro 11" 1st Gen Battery Replacement, Heat the left edge: step 18, image 1 of 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Ask FixBot
    18. iPad Pro 11" 1st Gen Battery Replacement, Left edge information: step 19, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Left edge information: step 19, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Left edge information: step 19, image 3 of 3
      • The left edge of the iPad contains several display cables. These cables are extremely fragile and easily damaged if an opening pick is inserted too far or at the wrong angle. Follow the instructions exactly as written to avoid damage.
      • The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
      • There are flat sections of the frame which require an opening pick to be inserted horizontally.
      Ask FixBot
    19. iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge adhesive: step 20, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge adhesive: step 20, image 2 of 2
      • Insert an opening pick at a 45˚ angle just above the bottom left corner.
      • Don't insert the pick more than 5 mm or you'll damage the display cables.
      • Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
      Ask FixBot
    20. iPad Pro 11" 1st Gen Battery Replacement: step 21, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement: step 21, image 2 of 2
      • Lower the opening pick so it is horizontal to the screen.
      • Don't insert the pick more than 5 mm.
      • Continue separating the left edge adhesive until you reach the next indented section of the frame.
      Ask FixBot
    21. iPad Pro 11" 1st Gen Battery Replacement, Separate the remaining adhesive: step 22, image 1 of 1
      • Separate the remaining adhesive, making sure to follow the instructions exactly as written.
      • Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
      • Slide the pick horizontally and don't insert the pick more than 5 mm.
      Ask FixBot
    22. iPad Pro 11" 1st Gen Battery Replacement, Separate the screen from the frame: step 23, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the screen from the frame: step 23, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the screen from the frame: step 23, image 3 of 3
      • Grab two opposing corners of the screen and gently separate the rest of the adhesive.
      • Don't fully remove the screen as it's held in place by several ribbon cables underneath.
      • Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
      Ask FixBot
    23. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the ambient light sensor cable bracket: step 24, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the ambient light sensor cable bracket: step 24, image 2 of 2
      FixMat
      $36.95
      Buy
      • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
      • One 1.3 mm screw
      • One 2.0 mm screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      Ask FixBot
    24. iPad Pro 11" 1st Gen Battery Replacement, Remove the ambient light sensor cable bracket: step 25, image 1 of 1
      Buy
      • Use tweezers or your fingers to remove the bracket.
      Ask FixBot
    25. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the ambient light sensor cable: step 26, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the ambient light sensor cable: step 26, image 2 of 2
      • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    26. iPad Pro 11" 1st Gen Battery Replacement, Reposition the screen: step 27, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Reposition the screen: step 27, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Reposition the screen: step 27, image 3 of 3
      • Don't try to remove the screen yet, as it's still attached by delicate ribbon cables.
      • Grip the right edge of the screen and fold it open like a book.
      • Lay the screen down over the left edge of the iPad.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the display cables: step 28, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the display cables: step 28, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the display cables: step 28, image 3 of 3
      • Use the pointed end of a spudger to pry up and disconnect the top two display cables.
      Ask FixBot
    2. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the remaining display cables: step 29, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the remaining display cables: step 29, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the remaining display cables: step 29, image 3 of 3
      • Disconnect the two remaining display cables.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Battery Replacement, Remove the screen: step 30, image 1 of 1
      • Grip the right edge of the screen and lift it away.
      • During reassembly, before installing a display, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
      • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
      • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the bottom cable shield: step 31, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the bottom cable shield: step 31, image 2 of 2
      • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the bottom cable shield to the logic board.
      Ask FixBot
    2. iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom cable shield: step 32, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom cable shield: step 32, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom cable shield: step 32, image 3 of 3
      • Use tweezers or your fingers to remove the bottom cable shield.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the battery: step 33, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the battery: step 33, image 2 of 2
      • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the USB-C port cable: step 34, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the USB-C port cable: step 34, image 2 of 2
      • Use the flat end of a spudger to disconnect the USB-C port cable.
      Ask FixBot
    2. iPad Pro 11" 1st Gen Battery Replacement, Separate the USB-C cable adhesive: step 35, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the USB-C cable adhesive: step 35, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the USB-C cable adhesive: step 35, image 3 of 3
      • The USB-C port cable is secured to the logic board with weak adhesive.
      • Slide an opening pick between the cable and the logic board to separate the adhesive.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the USB-C port: step 36, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the USB-C port: step 36, image 2 of 2
      • Use a Phillips screwdriver to remove the two 1.9 mm screws securing the USB-C port to the frame.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port grounding contacts: step 37, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port grounding contacts: step 37, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port grounding contacts: step 37, image 3 of 3
      Buy
      • Use tweezers to remove the two grounding contacts from each side of the USB-C port.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port: step 38, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port: step 38, image 2 of 2
      • Lift the USB-C port out of its slot in the frame.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the logic board shield: step 39, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the logic board shield: step 39, image 2 of 2
      • Use a Phillips PH00 screwdriver to remove the eight screws securing the shield to the logic board:
      • Five 2 mm screws
      • Three 1.2 mm screws
      Ask FixBot
    2. iPad Pro 11" 1st Gen Battery Replacement, Heat the logic board shield: step 40, image 1 of 1
      • Apply a heated iOpener to the top of the logic board for two minutes.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge shield adhesive: step 41, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge shield adhesive: step 41, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge shield adhesive: step 41, image 3 of 3
      • Insert an opening pick between the shield and the shielding gasket on the bottom edge of the logic board.
      • Slide the pick along the bottom edge to separate the adhesive.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge shield adhesive: step 42, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge shield adhesive: step 42, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge shield adhesive: step 42, image 3 of 3
      • Repeat the previous step for the right edge of the logic board shield.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge shield adhesive: step 43, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge shield adhesive: step 43, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge shield adhesive: step 43, image 3 of 3
      • Repeat the previous step for the left edge of the logic board shield.
      Ask FixBot
    6. iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board shield: step 44, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board shield: step 44, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board shield: step 44, image 3 of 3
      • Grip the logic board shield at the top and lift it up.
      • Stop lifting if the shield is stuck or begins to bend—a bent shield will reduce thermal transfer from the logic board. Use an opening pick to separate any remaining adhesive.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the IR dot projector cables: step 45, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the IR dot projector cables: step 45, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the IR dot projector cables: step 45, image 3 of 3
      • Use the pointed end of a spudger to disconnect the IR dot projector cable.
      Ask FixBot
    2. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the camera cables: step 46, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the camera cables: step 46, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the camera cables: step 46, image 3 of 3
      • Use the pointed end of a spudger to disconnect the front-facing camera and Face ID camera.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Battery Replacement, Separate the IR camera cable adhesive: step 47, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the IR camera cable adhesive: step 47, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the IR camera cable adhesive: step 47, image 3 of 3
      • The IR camera cable is secured to the logic board with weak adhesive.
      • Slide an opening pick between the IR camera cable and the logic board to separate it.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Battery Replacement, Separate the camera cable adhesive: step 48, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the camera cable adhesive: step 48, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the camera cable adhesive: step 48, image 3 of 3
      • Repeat the previous step for the camera cable.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the front camera module: step 49, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the front camera module: step 49, image 2 of 2
      • Use a Torx T3 screwdriver to remove the two 2.1 mm screws securing the front camera assembly to the frame.
      Ask FixBot
    6. iPad Pro 11" 1st Gen Battery Replacement, Loosen the front camera assembly: step 50, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Loosen the front camera assembly: step 50, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Loosen the front camera assembly: step 50, image 3 of 3
      • Use the pointed end of a spudger to pry up and loosen the front camera assembly.
      Ask FixBot
    7. iPad Pro 11" 1st Gen Battery Replacement, Remove the front camera assembly: step 51, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Remove the front camera assembly: step 51, image 2 of 2
      Buy
      • Use tweezers or your fingers to remove the front camera assembly.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Battery Replacement, Logic board cable removal information: step 52, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Logic board cable removal information: step 52, image 2 of 2
      • You're about to disconnect many connectors from the top and bottom of the logic board. During reassembly, use these photos as a reference to ensure all cables are connected in the correct locations.
      Ask FixBot
    2. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the rear camera interconnect cable: step 53, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the rear camera interconnect cable: step 53, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the rear camera interconnect cable: step 53, image 3 of 3
      • Use the flat end of a spudger to disconnect the rear camera interconnect cable.
      • Fold the interconnect cable over so the top right speaker cable is accessible.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top microphone cable: step 54, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top microphone cable: step 54, image 2 of 2
      • Use the flat end of a spudger to disconnect the top microphone cable.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top right speaker: step 55, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top right speaker: step 55, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top right speaker: step 55, image 3 of 3
      • Use the pointed end of a spudger to disconnect the two cables for the top right speaker.
      • Avoid prying against the short sides of the connector. The socket on the logic board is delicate and may break off if pried against.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top left speaker: step 56, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top left speaker: step 56, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top left speaker: step 56, image 3 of 3
      • Repeat the previous step for the two top left speaker cables.
      Ask FixBot
    6. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top interconnect board: step 57, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top interconnect board: step 57, image 2 of 2
      • Use the pointed end of a spudger to disconnect the top interconnect board.
      • Don't bend or reposition the interconnect board, as it will break if stressed.
      Ask FixBot
    7. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top Wi-Fi antenna cable: step 58, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top Wi-Fi antenna cable: step 58, image 2 of 2
      Buy
      • To disconnect antenna cables like this, use tweezers to grip the connector near the cable and lift it up.
      • Use the pointed end of a spudger to disconnect the top Wi-Fi antenna cable.
      • To reinstall, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets much like the metal snaps on a jacket.
      Ask FixBot
    8. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the Smart Connector and SIM card reader: step 59, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the Smart Connector and SIM card reader: step 59, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the Smart Connector and SIM card reader: step 59, image 3 of 3
      • Use the flat end of a spudger to disconnect the Smart Connector and SIM card reader cables.
      • For the Wi-Fi only model there is no SIM card reader cable.
      Ask FixBot
    9. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom right speaker: step 60, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom right speaker: step 60, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom right speaker: step 60, image 3 of 3
      • Follow the procedure in step 57 to disconnect the bottom right speaker.
      Ask FixBot
    10. iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom left speaker cable bracket: step 61, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom left speaker cable bracket: step 61, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom left speaker cable bracket: step 61, image 3 of 3
      • Use tweezers to peel back the tape securing the bottom left speaker cable bracket to the logic board.
      • Slide the bracket out horizontally.
      Ask FixBot
    11. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left LTE wireless cable: step 62, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left LTE wireless cable: step 62, image 2 of 2
      • Use the pointed end of a spudger to disconnect the bottom left LTE wireless cable.
      Ask FixBot
    12. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left speaker: step 63, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left speaker: step 63, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left speaker: step 63, image 3 of 3
      Ask FixBot
    13. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom interconnect board: step 64, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom interconnect board: step 64, image 2 of 2
      • Follow the procedure in 59 to disconnect the bottom interconnect cable.
      Ask FixBot
    14. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom Wi-Fi antenna cable: step 65, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom Wi-Fi antenna cable: step 65, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom Wi-Fi antenna cable: step 65, image 3 of 3
      • Use the pointed end of a spudger to disconnect the bottom Wi-Fi antenna cable.
      • Peel the cable away from the logic board and reposition it to the right.
      Ask FixBot
    15. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: step 66, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: step 66, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: step 66, image 3 of 3
      • Use the pointed end of a spudger to disconnect the left microphone and Apple Pencil charger cables.
      Ask FixBot
    16. iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol to the logic board: step 67, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol to the logic board: step 67, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol to the logic board: step 67, image 3 of 3
      • The adhesive that secures the logic board to the frame is very strong. To remove the board, follow the next steps to weaken the adhesive using high-strength (>90%) isopropyl alcohol.
      • Prop the left side of the iPad up against an object so the isopropyl alcohol can flow under the logic board.
      • Apply a few drops of isopropyl alcohol along the left edge of the logic board.
      • Be careful if you're using a syringe with a needle or other sharp instrument to dispense isopropyl alcohol—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Let the alcohol soak for one minute to soften the adhesive under the logic board.
      Ask FixBot
    17. iPad Pro 11" 1st Gen Battery Replacement: step 68, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 68, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 68, image 3 of 3
      • Rotate your iPad 180˚ and lay it down with the right side elevated.
      • Repeat the previous step for the right edge of the logic board.
      Ask FixBot
    18. iPad Pro 11" 1st Gen Battery Replacement, Pry up the logic board: step 69, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Pry up the logic board: step 69, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Pry up the logic board: step 69, image 3 of 3
      • Insert the flat end of a spudger between the logic board and the bottom right speaker.
      • Slowly pry up the bottom of the logic board.
      • If it is difficult to pry up the logic board, apply additional isopropyl alcohol and wait one minute.
      • Replace the playing card strips with an opening pick to block the battery.
      Ask FixBot
    19. iPad Pro 11" 1st Gen Battery Replacement, Release the logic board: step 70, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Release the logic board: step 70, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Release the logic board: step 70, image 3 of 3
      • Slide an opening pick under the left edge of the logic board to loosen it.
      • Pry against the frame underneath the logic board to separate the adhesive.
      • Don't forcefully lever against the battery—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • If the adhesive is still too strong to lift up the logic board, apply some additional isopropyl alcohol and wait one minute.
      Ask FixBot
    20. iPad Pro 11" 1st Gen Battery Replacement: step 71, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 71, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 71, image 3 of 3
      • Insert an opening pick under the right edge of the logic board above the left microphone and Apple Pencil charger cables.
      • Repeat the previous step for the right side of the logic board.
      Ask FixBot
    21. iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board: step 72, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board: step 72, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board: step 72, image 3 of 3
      Tesa 61395 Tape
      $8.95
      Buy
      • Grip the top and bottom edges of the logic board.
      • Remove the logic board.
      • Remove the old adhesive from the rear case and bottom of the logic board using tweezers and high concentration isopropyl alcohol with a lint-free cloth where needed.
      • During reassembly, apply strips of Tesa tape to the bottom of the logic board.
      Ask FixBot
    1. iPad Pro 11" 1st Gen Battery Replacement, Battery adhesive information: step 73, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Battery adhesive information: step 73, image 2 of 2
      Buy
      • There are 11 stretch-release adhesives that secure the battery to the frame. Each adhesive strip has a black pull tab:
      • Six on the inside edge of the left battery cell
      • Five on the inside edge of the right battery cell
      • The remainder of the adhesive is located under the battery boards.
      • Use your fingernails or tweezers to peel each pull tab away from the edge of the battery.
      • Be careful not to deform or puncture the battery—especially if you're using tweezers.
      Ask FixBot
    2. iPad Pro 11" 1st Gen Battery Replacement, Remove the battery adhesive: step 74, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the battery adhesive: step 74, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Remove the battery adhesive: step 74, image 3 of 3
      • Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery cells.
      • You can wrap the adhesive around a spudger to help keep the strip flat while pulling.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or tweezers, and continue pulling.
      Ask FixBot
    3. iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol: step 75, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol: step 75, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol: step 75, image 3 of 3
      • If you removed all of the stretch-release adhesive, good job! You can skip the next four steps. If not, then follow the next four steps to apply isopropyl alcohol.
      • Prop the left side of the iPad up against an object so the isopropyl alcohol can flow under the right battery cell.
      • Apply high-strength (>90%) isopropyl alcohol along the inside edge of the right battery cell.
      • Let the alcohol soak for two minutes to soften the adhesive under the battery cell.
      Ask FixBot
    4. iPad Pro 11" 1st Gen Battery Replacement: step 76, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 76, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 76, image 3 of 3
      • Rotate the iPad 180 degrees so the inner edge of the left battery is facing up.
      • Repeat the previous step for the left battery cell.
      Ask FixBot
    5. iPad Pro 11" 1st Gen Battery Replacement, Separate the battery adhesive: step 77, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the battery adhesive: step 77, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the battery adhesive: step 77, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Lay the iPad down flat on your work surface.
      • Starting at the top, insert a plastic card under the right battery cell.
      • Slide the plastic card toward the bottom of the iPad to separate the adhesive.
      • Stop sliding when you reach the Apple Pencil charger cable.
      • Don't force the card or bend the battery. If it's difficult to insert or slide the card, apply more isopropyl alcohol.
      Ask FixBot
    6. iPad Pro 11" 1st Gen Battery Replacement: step 78, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 78, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 78, image 3 of 3
      Ask FixBot
    7. iPad Pro 11" 1st Gen Battery Replacement, Separate the battery board adhesive: step 79, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the battery board adhesive: step 79, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement, Separate the battery board adhesive: step 79, image 3 of 3
      • Don't try to remove the battery yet – the battery boards are still held in place with adhesive.
      • Lift up the left battery cell.
      • Insert an opening pick under the left battery board and separate the remaining adhesive securing it to the frame.
      • If the adhesive does not separate easily, apply some high-strength (>90%) isopropyl alcohol and wait one minute.
      Ask FixBot
    8. iPad Pro 11" 1st Gen Battery Replacement: step 80, image 1 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 80, image 2 of 3 iPad Pro 11" 1st Gen Battery Replacement: step 80, image 3 of 3
      • Repeat the previous step for the right battery cell.
      Ask FixBot
    9. iPad Pro 11" 1st Gen Battery Replacement, Remove the battery: step 81, image 1 of 2 iPad Pro 11" 1st Gen Battery Replacement, Remove the battery: step 81, image 2 of 2
      Tesa 61395 Tape
      $25.95
      Buy
      • Lift both battery cells out of the iPad at the same time.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • Remove the old battery adhesive from the frame using tweezers and high-strength (>90%) isopropyl alcohol with a lint-free cloth where needed.
      • If your battery doesn't come with preinstalled adhesive, use Tesa tape to reattach the battery to the rear case.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 1st Gen answers community for help.
14 other people completed this guide.
Chayton Ritter
27,680 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
10 Guide Comments
My iPad will boot up but won't charge once it is on, would replacing the battery fix that?
I am Good - Reply Share
Extremely upset with this guide! It didn’t have me disconnect the battery first. When taking off the first display cable, the logic board sparked and shorted out, frying the whole thing! Not even my iPad which makes it so much worse.
Andrew Manger - Reply Share
Instructions for disconnecting the battery are ambiguous. It should be the first thing you do when the terminal is available?
Robb E - Reply Share
I completed this and the screen powers on (goes dark blue) but isn’t showing anything. The iPad makes sounds. Anyone have any tips?
isa.stewart - Reply Share
This is a great guide! Thank you.
filmcrash - Reply Share
Past 24 Hours: 41
Past 7 Days: 302
Past 30 Days: 1,377
All Time: 48,887
