Xiaomi Redmi Note 8T Battery Replacement
    1. Xiaomi Redmi Note 8T Battery Replacement, Xiaomi Redmi Note 8T Rear Glass Removal: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Xiaomi Redmi Note 8T Battery Replacement: step 2, image 1 of 3 Xiaomi Redmi Note 8T Battery Replacement: step 2, image 2 of 3 Xiaomi Redmi Note 8T Battery Replacement: step 2, image 3 of 3
      • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom right corner.
      Ask FixBot
    3. Xiaomi Redmi Note 8T Battery Replacement: step 3, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      • Don't remove the suction handle yet. You're going to use it later in the removal procedure as a rear glass stand.
      Ask FixBot
    4. Xiaomi Redmi Note 8T Battery Replacement: step 4, image 1 of 3 Xiaomi Redmi Note 8T Battery Replacement: step 4, image 2 of 3 Xiaomi Redmi Note 8T Battery Replacement: step 4, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Redmi Note 8T Battery Replacement: step 5, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 5, image 2 of 2
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Redmi Note 8T Battery Replacement: step 6, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 6, image 2 of 2
      • Do not insert the opening pick deeper than 5 mm to avoid damaging the fingerprint connector.
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      • Do not remove the rear glass all the way yet, the fingerprint cable is still connected to the motherboard.
      Ask FixBot
    7. Xiaomi Redmi Note 8T Battery Replacement: step 7, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 7, image 2 of 2
      • Carefully fold the rear glass to the right side of the phone. Use the suction handle as a stand for the rear glass.
      Ask FixBot
    8. Xiaomi Redmi Note 8T Battery Replacement: step 8, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 8, image 2 of 2
      • Use a spudger to pry up and disconnect the fingerprint flex cable.
      • Remove the rear glass.
      • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      Ask FixBot
    1. Careful: steps 9-11 are sourced from a guide that's marked as in-progress.
      Xiaomi Redmi Note 8T Battery Replacement, Xiaomi Redmi Note 8T Motherboard Cover Removal: step 9, image 1 of 1
      • Remove the eleven Phillips #00 screws (3.9 mm length).
      Ask FixBot
    2. Xiaomi Redmi Note 8T Battery Replacement: step 10, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 10, image 2 of 2
      • Insert the tip of an opening pick underneath the bottom edge of the motherboard cover.
      • Use the opening pick to pry up the motherboard cover.
      Ask FixBot
    3. Xiaomi Redmi Note 8T Battery Replacement: step 11, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 11, image 2 of 2
      • Remove the motherboard cover including the black protective foil that covers the battery.
      Ask FixBot
    1. Careful: step 12 is sourced from a guide that's marked as in-progress.
      Xiaomi Redmi Note 8T Battery Replacement, Xiaomi Redmi Note 8T Battery Disconnect: step 12, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement, Xiaomi Redmi Note 8T Battery Disconnect: step 12, image 2 of 2
      • Use a spudger to pry up and disconnect the battery flex cable.
      Ask FixBot
    1. Xiaomi Redmi Note 8T Battery Replacement, Battery: step 13, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement, Battery: step 13, image 2 of 2
      • Use a spudger to pry up and disconnect the main flex cable.
      Ask FixBot
    2. Xiaomi Redmi Note 8T Battery Replacement: step 14, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 14, image 2 of 2
      • Use a spudger to pry up and disconnect the display flex cable.
      Ask FixBot
    3. Xiaomi Redmi Note 8T Battery Replacement: step 15, image 1 of 3 Xiaomi Redmi Note 8T Battery Replacement: step 15, image 2 of 3 Xiaomi Redmi Note 8T Battery Replacement: step 15, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to carefully peel the black ends of the two adhesive strips off the bottom edge of the battery.
      Ask FixBot
    4. Xiaomi Redmi Note 8T Battery Replacement: step 16, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 16, image 2 of 2
      • Use a pair of tweezers to pull out the adhesive tabs from underneath the battery.
      • The adhesive tabs underneath the battery can rip very easily. Make sure you pull out the tabs in a slow and steady motion and in a flat angle. To prevent the adhesive tabs from ripping, it's helpfull to twist the strip around the tweezers.
      • If you manage to pull out both of the adhesive strips without ripping you can jump to Step 21 in order to remove the battery. If one of your adhesive strips rips during the removal, continue with the following step.
      Ask FixBot
    5. Xiaomi Redmi Note 8T Battery Replacement: step 17, image 1 of 1
      • Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
      Ask FixBot
    6. Xiaomi Redmi Note 8T Battery Replacement: step 18, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 18, image 2 of 2
      • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
      • Insert a spudger into the gap between the daughterboard cover and the battery at the bottom left corner of the battery.
      • Use the spudger to pry up the battery until you created a small gap underneath.
      Ask FixBot
    7. Xiaomi Redmi Note 8T Battery Replacement: step 19, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 19, image 2 of 2
      • Slide a plastic or playing card into the gap you created with the spudger.
      Ask FixBot
    8. Xiaomi Redmi Note 8T Battery Replacement: step 20, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 20, image 2 of 2
      Plastic Cards
      $2.99
      Buy
      • Slide the plastic card underneath the battery and cut the adhesive with it. Work your way along the left edge of the battery until you've loosened all adhesive.
      Ask FixBot
    9. Xiaomi Redmi Note 8T Battery Replacement: step 21, image 1 of 2 Xiaomi Redmi Note 8T Battery Replacement: step 21, image 2 of 2
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • Before adhering the battery, temporarily reconnect it to help align it correctly. Adhere the battery to the phone and then disconnect it and continue reassembling your phone.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, '''calibrate your newly installed battery''': Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
19 other people completed this guide.
Dominik Schnabelrauch
266,119 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
3 Guide Comments
Ein Tipp zu abgerissenen Klebestreifen, was nach 4 Jahren zu 98% passieren wird!
Zahnsteines hilft ungemein
EnRico - Reply Share
@ EnRico
Den Tipp verstehe ich nicht. Was ist "Zahnsteines"? ..Und inwiefern hilft das? Die Internetsuchmaschiene spuckt auch nichts dazu aus.
LiLaLego - Reply Share
Vielen Dank Spitze gut geführte Anleitung
Stefan Jürgen Hermann - Reply Share
Past 24 Hours: 16
Past 7 Days: 64
Past 30 Days: 310
All Time: 30,508
