Xbox Series X Base Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
167
All Time:
932
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace or remove the base (aka foot or circular pad) on an Xbox Series X.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
    1. Xbox Series X Base Replacement, Unlatch the base: step 1, image 1 of 3 Xbox Series X Base Replacement, Unlatch the base: step 1, image 2 of 3 Xbox Series X Base Replacement, Unlatch the base: step 1, image 3 of 3
      • Before you begin, completely power down and unplug all cables from your console.
      • A locking tab on the bottom of the shell (under the base) holds the base in place.
      • You can access the tab through the vent holes on the back of your Xbox, but you may need a flashlight. Alternatively, you can remove the back panel for easier access.
      • Stick a long, skinny flathead screwdriver through one of the vent holes on the back of your Xbox, near the locking tab.
      • Insert the screwdriver between the locking tab and the base. This might take a few tries—use a flashlight if you're having trouble.
      • Use the screwdriver to pry the tab inward (away from the base) into its open and unlocked position.
      • Keep the tab held open for the next step.
      Ask FixBot
    2. Xbox Series X Base Replacement, Twist and remove the base: step 2, image 1 of 3 Xbox Series X Base Replacement, Twist and remove the base: step 2, image 2 of 3 Xbox Series X Base Replacement, Twist and remove the base: step 2, image 3 of 3
      • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
      • Remove the base.
      • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
      • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
      Ask FixBot
Congratulations on completing your repair!
3 other people completed this guide.
Spencer Day
207,381 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,907 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 167
All Time: 932
