Up to 20% off select tools
Xbox Series X Back Panel Replacement
Views: 14K
View statistics:
Past 24 Hours:
51
Past 7 Days:
392
Past 30 Days:
1,785
All Time:
13,672
Comments: 5
5 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace the back panel on an Xbox Series X.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your console.
    1. Xbox Series X Back Panel Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X Back Panel Replacement, Uncover the back panel screws: step 1, image 2 of 2
      • Before you begin, completely power down and unplug all cables from your console.
      • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
      Ask FixBot
    2. Xbox Series X Back Panel Replacement: step 2, image 1 of 3 Xbox Series X Back Panel Replacement: step 2, image 2 of 3 Xbox Series X Back Panel Replacement: step 2, image 3 of 3
      • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
      • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
      • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
      • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
      Ask FixBot
    3. Xbox Series X Back Panel Replacement, Remove the back panel screws: step 3, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      Ask FixBot
    4. Xbox Series X Back Panel Replacement, Unclip the back panel: step 4, image 1 of 3 Xbox Series X Back Panel Replacement, Unclip the back panel: step 4, image 2 of 3 Xbox Series X Back Panel Replacement, Unclip the back panel: step 4, image 3 of 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
      • Pry up the back panel to release it from the locking clips.
      Ask FixBot
    5. Xbox Series X Back Panel Replacement: step 5, image 1 of 2 Xbox Series X Back Panel Replacement: step 5, image 2 of 2
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
      Ask FixBot
    6. Xbox Series X Back Panel Replacement, Remove the back panel: step 6, image 1 of 3 Xbox Series X Back Panel Replacement, Remove the back panel: step 6, image 2 of 3 Xbox Series X Back Panel Replacement, Remove the back panel: step 6, image 3 of 3
      • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
      • During reassembly, press along the edges of the back panel to snap it into place.
      Ask FixBot
    7. Xbox Series X Back Panel Replacement: step 7, image 1 of 3 Xbox Series X Back Panel Replacement: step 7, image 2 of 3 Xbox Series X Back Panel Replacement: step 7, image 3 of 3
      • The back panel slots into a gap at the top of the shell.
      • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
      • Remove the back panel.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
5 other people completed this guide.
Author
with
Carsten Frauenheim
175,088 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 51
Past 7 Days: 392
Past 30 Days: 1,785
All Time: 13,672
