Up to 20% off select tools
Vtech InnoTab 3S Buttons Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
88
All Time:
1,259
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
Are the buttons no longer working on your tablet? This guide will walk you through replacing the buttons on the Vtech InnoTab 3S.
    1. Vtech InnoTab 3S Buttons Replacement, Rear Panel: step 1, image 1 of 3 Vtech InnoTab 3S Buttons Replacement, Rear Panel: step 1, image 2 of 3 Vtech InnoTab 3S Buttons Replacement, Rear Panel: step 1, image 3 of 3
      • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
      • Remove the batteries from the device.
      Ask FixBot
    2. Vtech InnoTab 3S Buttons Replacement: step 2, image 1 of 3 Vtech InnoTab 3S Buttons Replacement: step 2, image 2 of 3 Vtech InnoTab 3S Buttons Replacement: step 2, image 3 of 3
      • Using a nylon spudger, remove the five caps that hide the screws.
      • Potential device damage: Be careful not to scrape the plastic from the device using the spudger.
      • For easier cap removal, hold the spudger vertically to the board and push, towards the bottom of the device.
      • Remove the five 5 mm screws from the rear panel of the device, using a Phillips #1 screwdriver.
      Ask FixBot
    3. Vtech InnoTab 3S Buttons Replacement: step 3, image 1 of 2 Vtech InnoTab 3S Buttons Replacement: step 3, image 2 of 2
      • Remove the six 7 mm screws from the interior battery compartment using a Phillips #1 screwdriver.
      Ask FixBot
    4. Vtech InnoTab 3S Buttons Replacement: step 4, image 1 of 1
      • Carefully remove the rear panel from the device.
      • Once the rear panel is removed, the motherboard and other components in the Vtech InnoTab 3S are visible and accessible.
      Ask FixBot
    1. Vtech InnoTab 3S Buttons Replacement, Buttons: step 5, image 1 of 3 Vtech InnoTab 3S Buttons Replacement, Buttons: step 5, image 2 of 3 Vtech InnoTab 3S Buttons Replacement, Buttons: step 5, image 3 of 3
      • The buttons on the InnoTab 3S are located in three areas. One on the left side of the tablet, one on the right side of the tablet, and on in the middle towards the bottom of the tablet.
      • Using a Spudger, gently lift the brown squares located on the left and right sides of the tablet to gain access to the buttons.
      • Replace the malfunctioning buttons and lower the brown squares back into place to secure the buttons to the device.
      • Unlike the other two buttons, the buttons located in the middle towards the bottom of the device can not be accessed without further dismantling of the device.
      Ask FixBot
    2. Vtech InnoTab 3S Buttons Replacement: step 6, image 1 of 1
      • Remove the motherboard to access the lower buttons. To remove the motherboard please see our Motherboard Guide
      • Now that the motherboard is removed, use a Spudger to gently lift the brown square at the bottom of the device.
      • Replace the malfunctioning buttons and lower the brown square back into place to secure the buttons to the device.
      Ask FixBot
Author
with
Karina Garcia
878 Reputation
6 Guides authored
USF Tampa, Team 8-2, Eyestone Fall 2015 Member of USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Members
108 Guides authored
1 Guide Comment
Into my heart i repair the vtech
Grant Lewis - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 88
All Time: 1,259
