Vtech InnoTab 3S Motherboard Replacement
    1. Vtech InnoTab 3S Motherboard Replacement, Rear Panel: step 1, image 1 of 3 Vtech InnoTab 3S Motherboard Replacement, Rear Panel: step 1, image 2 of 3 Vtech InnoTab 3S Motherboard Replacement, Rear Panel: step 1, image 3 of 3
      • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
      • Remove the batteries from the device.
      Ask FixBot
    2. Vtech InnoTab 3S Motherboard Replacement: step 2, image 1 of 2 Vtech InnoTab 3S Motherboard Replacement: step 2, image 2 of 2
      • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
      Ask FixBot
    3. Vtech InnoTab 3S Motherboard Replacement: step 3, image 1 of 3 Vtech InnoTab 3S Motherboard Replacement: step 3, image 2 of 3 Vtech InnoTab 3S Motherboard Replacement: step 3, image 3 of 3
      • Using a nylon spudger, remove the five caps that hide the screws.
      • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
      • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
      • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
      Ask FixBot
    4. Vtech InnoTab 3S Motherboard Replacement: step 4, image 1 of 1
      • Carefully remove the rear panel from the front panel of the device.
      • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
      Ask FixBot
    1. Vtech InnoTab 3S Motherboard Replacement, Motherboard: step 5, image 1 of 2 Vtech InnoTab 3S Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
      • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
      • Remove the six 3 mm screws securing the battery clip.
      Ask FixBot
    2. Vtech InnoTab 3S Motherboard Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
      • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
      • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
      Ask FixBot
3 other people completed this guide.
Karina Garcia
878 Reputation
6 Guides authored
USF Tampa, Team 8-2, Eyestone Fall 2015 Member of USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 27
All Time: 983
