Volkswagen Key Fob Battery Replacement
    1. Volkswagen Key Fob Battery Replacement, Identification: step 1, image 1 of 1
      • There are two main key fob models when it comes to repair.
      • If you see this shiny pin it means it’s the easiest of the two.
      • If this is not the case, the other iFixit guides on Volkswagen key fobs deal with the other replacement method.
      Ask FixBot
    2. Volkswagen Key Fob Battery Replacement, Opening: step 2, image 1 of 1
      • Pull from the small plastic square in the direction of the arrow to release the casing.
      Ask FixBot
    3. Volkswagen Key Fob Battery Replacement, Swap the battery: step 3, image 1 of 2 Volkswagen Key Fob Battery Replacement, Swap the battery: step 3, image 2 of 2
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert a spudger or a pointed object inside of the marked ledge to help release the battery.
      • Replace the battery and congrats!! You are done.
      Ask FixBot
4 other people completed this guide.
carlotremolada
2,974 Reputation
1 Guide authored
German Translators Member of German Translators
Community
51 Members
6,588 Guides authored
3 Guide Comments
very helpful!
drai - Reply Share
It's easy, but I was afraid of doing damage and was about to go to a Volkswagen centre. Very useful guide
Kodama - Reply Share
The key generally is too sensitive mine just stopped working and it was not the battery and I had to open the car manually . I lost the spare key and a new one took 2 months to order and cost about 250 dollars ! Yes you read that right !
Stephen J Whitworth - Reply Share
Past 24 Hours: 42
Past 7 Days: 186
Past 30 Days: 604
All Time: 9,056
