2001 Volkswagen Passat Key Fob Battery Replacement
    1. 2001 Volkswagen Passat Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 2 2001 Volkswagen Passat Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 2
      • Press the release button on the key fob so that key is extended.
      • Locate the small indentation in the middle of the key fob.
      Ask FixBot
    2. 2001 Volkswagen Passat Key Fob Battery Replacement: step 2, image 1 of 3 2001 Volkswagen Passat Key Fob Battery Replacement: step 2, image 2 of 3 2001 Volkswagen Passat Key Fob Battery Replacement: step 2, image 3 of 3
      • Place a plastic pry tool in the indentation of the key fob.
      • Apply pressure and rotate the pry tool until key fob begins to separate.
      • Using light force, pull the key fob apart.
      • Remove the cover on lower part of the key fob and locate the battery.
      Ask FixBot
    3. 2001 Volkswagen Passat Key Fob Battery Replacement: step 3, image 1 of 3 2001 Volkswagen Passat Key Fob Battery Replacement: step 3, image 2 of 3 2001 Volkswagen Passat Key Fob Battery Replacement: step 3, image 3 of 3
      • Use a spudger to remove the battery.
      • Place a new battery in the key fob and press down gently to secure it in place.
      Ask FixBot
    4. 2001 Volkswagen Passat Key Fob Battery Replacement: step 4, image 1 of 2 2001 Volkswagen Passat Key Fob Battery Replacement: step 4, image 2 of 2
      • Pick up the pieces of the key fob and begin to slide the pieces together.
      • This needs to be done slowly to not break the plastic on the fob.
      Ask FixBot
    5. 2001 Volkswagen Passat Key Fob Battery Replacement: step 5, image 1 of 1
      • Press the key release button to make sure that the key fob operates correctly.
      • Press the lock, unlock and trunk buttons and check for the red indicator light to make sure the key fob working properly.
      • Depending on your vehicle, you may need to reprogram your key fob to your car. Either consult a dealership or review your owner's manual on how to reprogram your key fob.
      Ask FixBot
Finish Line
6 other people completed this guide.
Alisha Kocjan
260 Reputation
1 Guide authored
2 Guide Comments
verry useful!!
eugen - Reply Share
My neighbor's key broke off the end for her 2001 Passat. She knowing that I am quite handy, asked me if I would try repairing it. I fixed it twice before. Now, instead of simply applying JB Weld again to the minimal surfaces and temporarily fixing it again, I want to disassemble it and repair the key with silver solder. I need a diagram of taking it apart so I can reassemble it so it functions like a new fold-up key fob should. This is such a handy thing, I just need to a diagram. C'mon, VW? Be a sport?
ironchip - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 81
All Time: 22,168
