Turtle Beach Recon 70P Microphone Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
67
All Time:
951
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If you find that your microphone has broken after extensive use or damage, you may want to take the opportunity to replace it before buying a new headset. This guide will take you through the steps necessary to ensure that your microphone replaced and working again.
Tools
    1. Turtle Beach Recon 70P Microphone Replacement, Microphone: step 1, image 1 of 2 Turtle Beach Recon 70P Microphone Replacement, Microphone: step 1, image 2 of 2
      • Before continuing, remove the left ear pad with the earpad replacement guide.
      • Ensure that you are removing the side that houses the microphone.
      • Use a spudger to pry up the black plastic housing.
      • Remove the plastic cover.
      Ask FixBot
    2. Turtle Beach Recon 70P Microphone Replacement: step 2, image 1 of 3 Turtle Beach Recon 70P Microphone Replacement: step 2, image 2 of 3 Turtle Beach Recon 70P Microphone Replacement: step 2, image 3 of 3
      • Use a Phillips screwdriver remove the two 5 mm screws that secure the motherboard.
      Ask FixBot
    3. Turtle Beach Recon 70P Microphone Replacement: step 3, image 1 of 3 Turtle Beach Recon 70P Microphone Replacement: step 3, image 2 of 3 Turtle Beach Recon 70P Microphone Replacement: step 3, image 3 of 3
      • Use a Phillips screwdriver to remove the single 8 mm screw under the motherboard that secures the microphone.
      Ask FixBot
    4. Turtle Beach Recon 70P Microphone Replacement: step 4, image 1 of 3 Turtle Beach Recon 70P Microphone Replacement: step 4, image 2 of 3 Turtle Beach Recon 70P Microphone Replacement: step 4, image 3 of 3
      • You may need to move the wire connecting to the speaker to easily remove the motherboard.
      • Remove the circuit board from the housing.
      • Take care not to strain the wires.
      Ask FixBot
    5. Turtle Beach Recon 70P Microphone Replacement: step 5, image 1 of 1
      • Desolder the microphone connections.
      • Soldering irons can cause burns and fires. Always solder and desolder in a well-ventilated workspace.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 67
All Time: 951
