Up to 20% off select tools
Tungsten E Power Button Repair
Views: 5.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
91
All Time:
5,932
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
How to repair a loose power button.
    1. Tungsten E Power Button Repair, Tungsten E Disassembly: step 1, image 1 of 2 Tungsten E Power Button Repair, Tungsten E Disassembly: step 1, image 2 of 2
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
      Ask FixBot
    2. Tungsten E Power Button Repair: step 2, image 1 of 3 Tungsten E Power Button Repair: step 2, image 2 of 3 Tungsten E Power Button Repair: step 2, image 3 of 3
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
      Ask FixBot
    3. Tungsten E Power Button Repair: step 3, image 1 of 2 Tungsten E Power Button Repair: step 3, image 2 of 2
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
      Ask FixBot
    4. Tungsten E Power Button Repair: step 4, image 1 of 2 Tungsten E Power Button Repair: step 4, image 2 of 2
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
      Ask FixBot
    5. Tungsten E Power Button Repair: step 5, image 1 of 3 Tungsten E Power Button Repair: step 5, image 2 of 3 Tungsten E Power Button Repair: step 5, image 3 of 3
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
      Ask FixBot
    6. Tungsten E Power Button Repair: step 6, image 1 of 1
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
      Ask FixBot
    1. Tungsten E Power Button Repair, Tungsten E Power Button Repair: step 7, image 1 of 1
      Ask FixBot
    2. Tungsten E Power Button Repair: step 8, image 1 of 1
      • On the motherboard, find the power button near the upper right corner.
      • Check for disconnection of the power button.
      Ask FixBot
    3. Tungsten E Power Button Repair: step 9, image 1 of 1
      • Use soldering iron to reattach the damaged power button to the motherboard.
      Ask FixBot
Author
with
Kathleen Hix
49 Reputation
2 Guides authored
Cal Poly, Team 13-22, Maness Winter 2010 Member of Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 91
All Time: 5,932
