Up to 20% off select tools
Tungsten E Battery Replacement
Views: 7.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
125
All Time:
7,772
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Parts
Tools
Introduction
Go to step 1 ↓
This is a repair guide for battery replacement.
    1. Tungsten E Battery Replacement, Battery: step 1, image 1 of 1
      Ask FixBot
    2. Tungsten E Battery Replacement: step 2, image 1 of 1
      • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
      • Caution: the battery is connected by two wires.
      Ask FixBot
    3. Tungsten E Battery Replacement: step 3, image 1 of 1
      • Remove the battery
      • Caution: Be careful not to tear the wires when removing battery.
      Ask FixBot
    4. Tungsten E Battery Replacement: step 4, image 1 of 1
      • Using a soldering iron, disconnect the battery wires.
      • Note: the wires are soldered to the board.
      Ask FixBot
    5. Tungsten E Battery Replacement: step 5, image 1 of 1
      • Take replacement battery and solder the wires to the board.
      • Take care to match wire colors as before.
      • Use double sided tape to attach battery firmly to board.
      Ask FixBot
Author
with
Kathleen Hix
49 Reputation
2 Guides authored
Cal Poly, Team 13-22, Maness Winter 2010 Member of Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 125
All Time: 7,772
